Giant power 4S 5000 mah 65c-130c lipo problems?
  • Andris Golts
    • Jan 2011
    • 504
    Hi all 2 years ago i purchased 2- 4s Giant power 5000 mah lipo's always stored at 60% in winter +cycle 3 time's during the off season never discharged them below 30% and never had them heat up more than 15 degrees over ambient temerature i had 1 pack go south last fall and the other one give out last week. They both swelled to twice there size both packs where barely warm when this happened i also use a stopwatch with a alarm i also use the blue Turnigy 4s 5000 mah 40c lipo's under the same parameters and never had any issues except the boats may be 4 mph slower than the Giant power lipo's. Has anyone else had this issue ? very frustrating cosidering the Giant power lipo's where 3x the price of the Turnigy's ! Regards Andris Golts.
  • TRUCKPULL
    • 2975
    When you charged or discharged your packs what was the voltage balance?
    I use the Hyperion chargers. they balance packs down to 0.002 Volts between all cells in the pack.
    That is 2 thousand's of a volt.
    Some people say 0.020 is Ok
    If I put a pack on my pack checker, and it reads 0.020 or above, I get an alarm.
    Larry
    • Doug Smock
      Moderator
      • 5272
      Two years ago those would have been the packs in blue semi transparent heat shrink correct? If so your experience is not uncommon. It is my understanding that the current cells are much better although I haven't run any myself.
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Andris Golts
        • Jan 2011
        • 504
        Hi Larry voltage balance was 4.19v -4.22v . Doug they where the packs in blue semi transparent heat shrink. Thanks to both of you for your replies. Regards Andris Golts.
        • photohoward1
          • 1611
          Same issue. Don't blame Giant Power. That run of Batts from who ever made them was awful. My hyperion packs from the same time all were garbage. Bob made good on them but that was 2 years ago after one weekends use.
          • TRUCKPULL
            • 2975
            Hi Larry voltage balance was 4.19v -4.22v Regards Andris Golts.
            4.19v -4.22v = 0.030v = 3 hundredths
            Max should be about 0.015v thousands.
            Also your balance checker should go to 0.000 (3 decimal places)
            Larry
            • T.S.Davis
              • 6220
              There was a whole era of batteries I had trouble with. I think they all copy each other. I had issues with some Thunderpower puffing around the same time that the blue GP's were out. The worst were the HV cells. Horrible.
              Noisy person
              • Doby
                KANADA RULES!
                • 7280
                There's a big factory in China that builds cells/packs...think its call "LiPos R Us"...different labels get slapped on them at the end before shipping.
                Grand River Marine Modellers
                • Bp9145
                  • Jan 2016
                  • 1466
                  This problem is not uncommon. I just recently had some go bad. I cycle all my batteries every 3 months and this time a few of my batteries ended up with one dead cell. Thunder Power 6S 5000mah, Thunder Power 4S and 6S 2250mah, and a couple of Gens Ace 4S 2200mah all had one bad cell. All were brand new, stored properly, kept inside the house with 71°-73° temps and just over a year old. Tried reviving the dead cells and was unable. Had a couple last year also but I was able to revive the cells. The only thing to do is either take the bad cells out or just leave them as is and just use them as 5S, 3S or 2S or sell them as is, not sure what I'm going to do yet. It's frustrating but it happens even with the more expensive and better brands. Doby's probably right about "LiPos R Us". .LOL
                  • grsboats
                    • Jul 2012
                    • 975
                    I bought 6 Revoelectric packs silver label (6S 5.0A 60C) one year and a haft ago and two of them have one dead cell under normal use and proper storage....I wonder when this quality control will be improved as the two have less than twenty charges.!? Gill
                    GO FAST AND TURN RIGHT !
                    www.grsboats.com.br
                    • rearwheelin
                      • 1941
                      LOL !! I just bought 4 used packs matching your description !! They are not puffed and balanced perfectly, hopefully they stay that way . Reading the rest of the comments here I’m seriously considering to never buy the highest performance batteries again! I had brand new RevLectrix go south on the shelf also .
                      --Albert Einstein
