Battery wire length
  • Beaux
    • Dec 2015
    • 550
    Battery wire length
    I'm building a Vortex 34 and I need about two inch longer battery wires for placement. Is it better to make the esc wires longer or the battery wires longer?
    thanks,
    Beaux
  • CraigP
    • May 2017
    • 1464
    ESC... Because batteries can bite! Also, they don’t need the heat... Good luck on your build! I hope we can see some pics of it coming together
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      Some guys may frown upon this, but I would make an extension between the two with bullet connectors on either side. I wouldn’t try to solder more wire to the battery or esc.
      • CraigP
        • May 2017
        • 1464
        Adding connectors is really putting in a bunch more resistance. If you are running HV and lower current, then no problem. But if you are running over 180A, you might want to do the math on that first. Just one guy’s opinion...
        • Beaux
          • Dec 2015
          • 550
          Thanks guys, and yes pictures are on the way.
            Make Total Destroy
            • Mar 2014
            • 1952
            Yeah I try never to do it, but ya know, I’d rather a connector than just soldering wire together. I suppose we don’t know his setup so more info would help, tho on a vortex 34, how many amps is he really gonna pull. I mean, it’s not exactly a hull that requires a large high power system as far as I know.
              Mine pulled an average of over 200 amps to be competitive....
                Make Total Destroy
                • Mar 2014
                • 1952
                Oh wow... ok yeah that’s a fair amount.
                Any advice for the op? You’re more knowledgeable than I am sir
                  The OP has already been given good advice.
                  • Beaux
                    • Dec 2015
                    • 550
                    Sorry about the lack of info, TP 4070 2200kv, Swordfish 240 hv on 4sx2. While I've got you guys on the line what do you think about leaving the antenae internal under the hatch.
                    • Prodrvr
                      • Jul 2015
                      • 701
                      Does your boat have any carbon fiber in it? If so, have the antenna stick out of the hull.
                      • Norwest
                        • Mar 2014
                        • 165
                        How about using a thicker wire for extension like one size larger than present wire of esc to use. Replies on this are welcome!
                        • Gray
                          Banned
                          • Dec 2019
                          • 3
                          As others have said, lengthen can lead to increased battery resistance, so try to keep the length as low as possible. It is also better to use a plug connection than welding. There is a certain risk of welding, and using a plug connection, you can use it later in other places.
