Power Hobby lipo
  • be8843
    • Mar 2016
    • 47
    Power Hobby lipo
    Anyone use kinexsis lipo batteries? Are they any good?
  • fweasel
    master of some
    • Jul 2016
    • 4291
    Never heard of them. I have been using Turnigy and Rvolectrix graphene 3S packs over the last season with good results. You want a pack with a high C rating and the Kinexsis you mentioned seemed to only be 30C. 50+ is preferred for faster electric boat applications.
    Vac-U-Tug Jr (13mph)
    • be8843
      • Mar 2016
      • 47
      I would be using these on my stock stealthwake. If I like them I'll get the larger c rated batteries for my next boat.
      • fweasel
        master of some
        • Jul 2016
        • 4291
        IMO, wasted money. Why not spend only a little extra now, and then you have a larger cache of batteries that can be used in any of your boats later on? An alternative theory anyways, and not my money to spend.
        • be8843
          • Mar 2016
          • 47
          Good point, I also don't see where the kinexsis has anything over a 35c.
          • be8843
            • Mar 2016
            • 47
            Where do you get your turnigy batteries from?
            • fweasel
              master of some
              • Jul 2016
              • 4291
              Hobbyking. I get the Revo's from OSE.
              • be8843
                • Mar 2016
                • 47
                Can you get revo batteries on here with the ec5 connector?
                • fweasel
                  master of some
                  • Jul 2016
                  • 4291
                  They come with bare leads. Solder on whatever connector you like.
                  • Erroneous
                    • Apr 2016
                    • 451
                    You can order direct from Revolectrix Singapore with what ever connectors you want. Delivery time is about 5 days.
                    • be8843
                      • Mar 2016
                      • 47
                      That's what I did last night. I hope it's 5 days. My Miss Geico 29 should come in next week
                      • Erroneous
                        • Apr 2016
                        • 451
                        I like tracking the orders from them. They go through three foreign wars and still make it in record time.
                        • be8843
                          • Mar 2016
                          • 47
                          I'm hoping so, mine hasn't shipped yet.
                          • Linewbie
                            • Apr 2017
                            • 143
                            Took your advice and ordered a pair the other day, thanks. Quick question though pls. For 10.00 more than I usually buy, the 5000Mah 420 3s, I bought a pair of 435's, assuming I can charge them to that number. Preliminary investigation into my owners manual indicated my charger will only charge up to 4.20v ( Ultra Power UP200AC DUO ) so what am I to do? Do any of you guys know if there is a work around to charge these up to the 4.35v, or am I stuck charging a 4.35v to only 4.20v, which probably isn't good for the battery at worse, and at best I pissed away an additional 10.00 per battery that I can't get the most out of. Thanks
                            • fweasel
                              master of some
                              • Jul 2016
                              • 4291
                              Your charger would need a LiHV setting to charge to 4.35V. You can charge a 435 pack to 4.2 with no problems, in fact, the pack life will be increased because of it, all other conditions being equal. However, the rated capacity in mAh is based on a 4.35V charge, so if you charge to 4.2V, the packs will output less than 5000mAh. How much less, I don't know off the top of my head.
                              IMO, you spent $20 you didn't need to and got batteries that weren't the best match for your needs.
