I have what i hope is not a silly question. I have a Proboat Zelos 36 and am running a 4 battery setup. My question is, is it OK to run 2 3s 5200mah 50c batteries and 2 3s 5200mah 75c batteries. So what I was thinking was one 50c and one 75c together to one esc and one 50c and one 75c to the other esc? is that ok or a huge no no?
Battery question (new guy)
Tags: None
I am NOT saying NO don't do it.
But to be safe the rule of thumb is all batteries should be of the same type, size, and chemistry.
If not one battery pack can get run down too far, and the other pack is still good before you see a performance drop.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Bump & Grind Racing Props -We Like Em Smooth & Wet -
Thanks for the advise, I think I will just order 2 more of the 50c to be safe! Thanks again for the fast response !Comment
The higher the "C" rating along with the higher "mah" rating gives you HIGHER Voltage Under Load
Voltage under load is RPM on your motor, seeing that our motors are rated as KV
KV stands for RPM per Volt.
Bump & Grind Racing Props -We Like Em Smooth & WetComment
good info! Then ill get 2 more of the 75c! Thanks so much!! i don't want to violate forum rules but since your here, I don't suppose you could recommend the best prop for my boat? I don't want to mess with sharpening or balancing, something I can install right out of the box that will increase performance?Comment
NEVER SATISFIED RACING
Fine Design 32 V-Hull 4082+6sComment
