4s vs 2 2s packs
  • Mr.T
    • Dec 2015
    • 4
    4s vs 2 2s packs
    Are there any advantages or disadvantages to running 2 2s packs in series vs one 4s pack?
  • JimClark
    • 5907
    weight distribution
    Billy Graham
    • fweasel
      master of some
      • Jul 2016
      • 4291
      Depends on many factors. 2 2S packs can give you better weight distribution depending on the hull. They can also increase heat and decrease peak current output by adding more connections and resistance to the electrical circuit. What's your application?
      Vac-U-Tug Jr (13mph)
      • Mr.T
        • Dec 2015
        • 4
        Application will be a FE tunnel
        • fweasel
          master of some
          • Jul 2016
          • 4291
          Unless you're trying to use packs that you already own, a single 4S pack with only enough capacity for your intended runtime and electrical draw would be the most simple and compact solution.
          • Mr.T
            • Dec 2015
            • 4
            Sounds good, thanks
