What connectors for 8s?
  • Hi8iS
    • Jul 2009
    • 271
    Hello, I just picked up a Joysway Silverline. It comes with a Leopard 5692 1050KV & a Hobbywig 130a HV ESC. I plan on running 8s & eventually want to try 10S. All my other stuff is set up to run 5.5mm bullets. Can I get away 5.5 bullets on this higher voltage setup? Or do I need to step up to 8mm connectors?
  • RaceMechaniX
    • Sep 2007
    • 2831
    It really depends on the your current level, but based on the 130A limit of the controller you should be fine sticking with 5.5mm's.
    TG
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • Hi8iS
      • Jul 2009
      • 271
      TG
      Thanks for the help. Still very new to this & not trying to learn from my mistakes :). Another battery related question. My charger has 5.5 bullets on the end. If I do go with 8mm bullets is it ok to make an 8mm to 5.5mm adaptor to charge my packs? I'm guessing it doesn't matter as the y only charge at 10 amps.
      • RaceMechaniX
        • Sep 2007
        • 2831
        That is fine, charging is low amperage and will not affect anything.
        Tyler
        Tyler Garrard
        • Hi8iS
          • Jul 2009
          • 271
          Tyler
          I figures that to be the case. Thanks again! Learning so much from this site!
          • Hi8iS
            • Jul 2009
            • 271
            Another question in regards to this setup. I have (4) 4s 4500mah 40 C Lipos. I plan on running two in series to achieve 8s. I know wiring in series doubles your voltage. But what about the C rating? WIll this double as well? How about if I ran all 4 packs? Two sets of 4s wired in series, then wired in parrallel to double my capacity & give me 9000mah for extra run time. Would this effect my C rating? Also is there a target mah one should try to achieve? Is 9000 to much? Can running on 8s for to long overheat things?
            • RaceMechaniX
              • Sep 2007
              • 2831
              When you parallel batteries you theoretically double the C rating as the current draw is split between the two batteries. C rating is related to capacity so larger capacity cell can deliver more current for the same C rating.
              As with any new set-up the best advise is to start with small props and short run times. Run for 2 minutes, bring the boat in and check the battery voltage and temperature. As a general rule of thumb you want to come in with 40% of battery capacity remaining and temps should be warm but not hot. Batteries should be between 100 and 120F, Controllers and motors should be below 130F.
              TG
              Tyler Garrard
              • Hi8iS
                • Jul 2009
                • 271
                Thanks again. All this is starting to make sense!
