How I made a 3p battery harness.
--Albert EinsteinTags: None -
Not sure what kind of harness that is, looks like a 3 cell SERIES connector. so if you are running 3s lipo(as an example) you would be running 9s.............I think, it looks very unique...........but not like parallelNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
It is for hooking them up in parallel for my Team Believer ! I should have made it clearer in the OP ! My badI mainly wanted to show how easy it is to join 8 gauge and bullets using a torch .
--Albert EinsteinComment
Your soldering and creating skills are very good but it still seems like it will not work in parallel.................it looks like a series connector. Maybe someone else will post.................maybe im nuts.................NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I suppose I could series the packs first and then plug into the harness, that would work !"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
