P Sport Hydro 1P or 2P
  • ezhitz
    • Aug 2009
    • 428
    Hi I plan on building a p hydro for next season and I'm wondering should I build it around 2P or 1P. If the best set up is 2P would I have to run 5000 mah or could I use 3700 - 4000 mah to save on the weight. I will be building a whip20.
    :canada
  • photohoward1
    • 1611
    1p IMO. You could get away with using only 5k total. I run a whip 20 with only 4200. 2 2s packs side by side up front. Flat in the nose. You really don't have to pull many amps to go fast with that boat. What motor were you considering?
    • ezhitz
      • Aug 2009
      • 428
      I'm going to use a TP 4050 2200kv. I did run that motor in my Jae21 last summer on a 5000mah 7 laps no problems .
      :canada
      • Doby
        KANADA RULES!
        • 7280
        The extra weight of 2P can be your friend sometimes...
        Grand River Marine Modellers
        • photohoward1
          • 1611
          I have always tried to go the lighter route. Lighter boats turner better. But they can fly higher too.
          • RaceMechaniX
            • Sep 2007
            • 2831
            The whip is somewhat unique and the best ones I have seen run 1P with either a 5000 or 6000mAh pack usually split into 2S and laid flat up in the nose.
            Tyler Garrard
            NAMBA 639/IMPBA 20525
            T-Hydro @ 142.94mph former WR
            • Shooter
              Team Mojo
              • Jun 2009
              • 2558
              Agree. I'm learning this as well.....and having most of the weight at the CG helps too!
              Howard - Is that full P that you are running only 5K? (FWIW, I'm the fool that runs 8000mah, but voltage at the end of the race is a good thing too!!).
              • photohoward1
                • 1611
                Yes full p. Not the fastest but I'm trying to be efficient. I can't keep it on the water anyway. Trying to keep it to 100 amps. It runs upper 50s. Above that it blows off.
                • ezhitz
                  • Aug 2009
                  • 428
                  Thanks for the input I do have some 5000 mah dinogys I could run or just use my 5200 40c revo. I wonder with the higher C rated batteries is 2p still needed in a boat drawing 100 amp draw.
                  :canada
                  • madmikepags
                    • Aug 2012
                    • 1359
                    2P is almost never needed for racing anymore except for in offshore, 5-6000 mah is plenty for almost any application even 10S setups in 1/8 scale and even 10s riggers.
                    We call ourselves the "Q"
                    • ray schrauwen
                      • 9475
                      What motor Howard, a 1515 1Y neu??
                      • ray schrauwen
                        • 9475
                        I had no idea some people were running 1P in P-Sport hydro. A whip 20 has so much lift that 10,000mah doesn't slow it down much if at all that I know of but, may be pulling more amps than needed. I know TRUCKPULL Larry J. runs 10K in his P-sport whip. I never had a P-sport ready for the Nats and I never asked any of the guys what they were using for setups.
                        • TRUCKPULL
                          • 2975
                          Yes I run
                          4S - 2P - 5000 - 56-130C =10k total
                          1515 1Y NEU
                          Modified 442-3
                          You need the weight to keep it from flying.
                          And the voltage under load to make it fast.
                          Higher mAmp packs + higher C packs = Higher voltage under load. remember our motor's are KV.
                          If you have a higher voltage under load that equals more prop RPM = more speed.
                          My hull is not stock. It is cut to release more air.
                          78 Sec. for 1 mile - running in lane 4 to 5
                          Larry
                          • photohoward1
                            • 1611
                            1515 Ray. 10k Larry? That thing should run 10 minutes.
                              • 8011
                              One club member runs 4S1P/5000mAh in his self-designed PSH powering a Neu 1521/1.5D. He finishes with around 2000 mAh remaining, and his boat is very fast.
