Soldering 5.5 mm bullet connectors- best way
  • AB Bob
    • Jul 2014
    • 42
    I'm going to be converting my batteries to 5.5 mm bullet connectors.
    I'm wondering what type iron and what type tip would be the best for this action.
    Thanks for your input!
    Bob
  • revoltrunner
    • May 2014
    • 646
    here's what I use , works great.
    • AB Bob
      • Jul 2014
      • 42
      Thanks for your reply.
      Do you use any type of jig to hold things while you do the soldering? I was wondering if those so called "helping hands" were worth their $$$ ?
      • revoltrunner
        • May 2014
        • 646
        I just put the bullet in vise grip pliers laying on
        a hunk of board. just clamp it lightly though.
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          I just drilled a set of holes in the corner of my bench for 4mm 5.5mm & 8mm male & female bullets. A snug fit & deep enough to hold them upright. Free.
          • flraptor07
            • Aug 2013
            • 2451
            I've got this Maxtra 952D, I've had it for almost 2 years now and it's worked flawless. Can't beat it for the $, and I really like the hot air wand for doing heat shrink. http://www.ebay.com/itm/2-In-1-SMD-H...item2577af7e83
            • flraptor07
              • Aug 2013
              • 2451
              Also have one of these, one of the handiest tools I've ever bought! http://www.ebay.com/itm/like/231333329388?lpid=82
              • Brewbud
                • Aug 2014
                • 117
                I have a board I drilled for both the male and female plugs similar to what 785boats is doing. I use my 60W solder station. There are several nicely detailed youtube videos out there that will help.
                Knowledge is knowing a tomato is a fruit. Wisdom is knowing not to use it in a fruit salad.
                PB BlackJack 29 / AQ Motley Crew / Tenshock Mini ECO / Phil Thomas Stealth
                • Brewbud
                  • Aug 2014
                  • 117
                  That jig looks pretty handy!
                  • revoltrunner
                    • May 2014
                    • 646
                    that's pretty neat , I like the warning better though....lol
                    Note: Aluminum is a conductive material, never place 2 plugs from the same battery pack in Mr Jig simultaneously or Else it would goes up in Fire
                    • AB Bob
                      • Jul 2014
                      • 42
                      Quick, easy and heavy enough not to move around. Thanks for the idea.
                      • AB Bob
                        • Jul 2014
                        • 42
                        I like "free" a lot! Thanks.
                        • AB Bob
                          • Jul 2014
                          • 42
                          I like that Maxtra station! Very nice. I like that jig too. I think I could benefit from that. Thanks.
                          • AB Bob
                            • Jul 2014
                            • 42
                            Seems that between 60W and 100W would be the ideal wattage...Thanks.
                            • AB Bob
                              • Jul 2014
                              • 42
                              Good point!
