Can I parallel charge 2 6s 5000 mah and 2 5500 mah 6s together at the same time thanks in advance for any and all help
parallel charging on three powerlab 8
Tags: None
Yes the charger won't have a problem with that. But your power supply needs to be rated to at least 25A at 24V or 45A at 12V to give you the 500+ watts you will be drawing for a 1C charge on all 4 batteries.
Different capacities or C ratings aren't a problem when parallel charging if that was your main concern. Just make sure the packs are close in cell voltage first & plug all the main power leads in and let the voltages equalise for a couple of minutes BEFORE you plug in any balance leads.
I'm a great fan of parallel charging but I only ever do two big 6s packs at a time myself. On my Hyperion Duo charger I can do two packs on each channel at the same time, giving a total of 4.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Yep. Page 74 of your manual.See the danger. THEN DO IT ANYWAY!!!
