I have a 6s 65c 5500 mah and a 6s 65c 5000 mah battery both have maybe 5 runs on them. My question is can i hook these together in series or do they have to be the same mah ? thanks for any help,geno
pulse batteries
Tags: None
You can, it will work but its dangerous. I answer this with experience. Ive done it. I didnt have a problem but i did not run it long. You run a risk of running the lower capacity battery lower than the safe limit. ive mixed differnt c rating batteries too. Never ran anything long and I really dont recommend doing it.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
It is not a real problem as long as you are aware of what you are doing.
In your case you would rate the whole series pack as a 5000mah pack. When using the 20% remaining rule you will only use 4000mah out of the pack. This will leave the resting voltage of both packs at 3.7V/cell after your run.
Do not be tempted to run any longer or you will ruin the 5000mah pack.
Your choice.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Your choice.
run it like they both are 5000mah with your times....NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
