Different capacity mah can use parallel plug together to play ?
  • Shun Tung
    • Oct 2012
    • 121
    Dear all master ,
    I have a question don't understand and very confuse . I have 7.4 v
    4400 mah 65 c lipo . I hope make more time to run . So , my friend
    told me use parallel plug connect another same volt and C rate together
    to play . You may get more time to play . My question is if I use 7.4 v
    1800 mah 65 c parallel plug connect to another 4400 mah 7.4 v 65 c
    Lipo . That's mean will be change to 6200 mah 7.4 v 65 c lipo ??
    Is it correct or wrong ? Or it must be use the same capacity mah lipo
    to make it ! Would you please any master give me advise and recommend to me !!!! I really hope the correct answer to make my decision . Thank you so much ervery one !!
  • NativePaul
    Greased Weasel
    • 2761
    In theory, yes you can do that. In practice, I don't know anyone who has actually run with unequal cells in parallel.
    • oscarel
      • Dec 2009
      • 2128
      Works perfectly. I run 5000 with 2250 for total of 7250mah.
      • Shun Tung
        • Oct 2012
        • 121
        Hi oscarel ,
        You mean's I can parallel difference capacity mah together to run . Just only need same volt and C rate is ok ?
        Please advise ! Thanks !,
        • oscarel
          • Dec 2009
          • 2128
          Correct, here's a pic of what I have used. Larger lipos in back series for 10s, smaller in front also series for 10s. Both these parelleled to add together mah.
          • Shun Tung
            • Oct 2012
            • 121
            Very great job and thank you your advise ! I will be following you and make this parallel lipo job .
            I really thank you so much your information .
