charging battery questions lipo
i know i new but still trying to get this all going . when charging lipo do u just plug in the balance plug and the set to charge are do u use the banana plug to the battery that has deans plugs are plug in both.
also i got a shockwave 26 bl. it call for a 3 s lipo but not sure what to get to make this boat run well and not burn it up. i want it to preform well. i have Capacity: 5000mAh
Voltage: 2S1P / 2S Cell / 7.4V
Discharge: 35C Constant / 70C Burst. but wanting to get some 3 s for this boat. will the 2 s work i have. and what 3 s battery's to get for this. i was just going to start with some Turnigy are something like that. till i get better . i just dont know how to match up with the 20 are 30 c and miliamps and so on.
thanks everyone for the help1 motley crew- under construction 2x shock wave 26-2 x surge crushers - 1 30' monoComment
Plug the balance to the balance port and the discharge lead to the chargers bananas. Set for LIPo BALANCE CHARGE, 5 amps and 2 cells (2S) for the first battery you asked about.
The more the C rating the higher the load it will take without damaging the pack. The milliamp hour (mah) is the capacity. The higher the longer it will run a load.Comment
