Battery setup 1P or 2P same Mah Please share your opinion
  • Xcesive8
    • Jul 2009
    • 395
    Hi Guys
    Boat : Radtek/Hpr 2.33m
    Motors: Neu 2230 1y 725kv
    Esc's: Schulze 40.334WK
    Batterys : 12s setup each side
    Im at the stage where the boat is complete and i just need to purchase batterys.
    Ive been speaking with Mark on here about his Dinogys and had planned to buy packs off him.
    I like what i hear about them so figure there the way to go..
    I was going to buy 8 x 6s 6000Mah 65c packs
    or even 6s 5000mah 65c packs not 100% yet
    So 4 each side and obviously each pair in series to give me 12s 2P 10,000 - 12,000 Mah
    Dinogy 5000mAh 6s 65C
    Specifications:
    •22.2V
    •Max Charge Rate6C/36A
    •Pack Weight 825
    •Pack Size 54x48x160mm
    So 8 x = 6.6kg
    But have since found some packs from another reputable brand that i use in my Electric Helis that are now doing
    6s 10,000mah 60c packs.
    So i could just run 1P but still retain the same MAH.
    Revolectrix 10000mAh 6S Lipo - Diamond Label -
    Size: 104mm thick x 44mm W x 152mm L,
    Weight: 1575 grams, Ratings: 60C. Cont. 120C Burst. 6C Charge Rate
    4x = 6.3kg
    So my Questions
    Is it pretty much the same deal?
    Or is it just better to have power coming from 4packs as opposed to 2?
    The wiring with the 1P setup will be alot shorter considering Schulze say to count every bit of wire from esc to cell tab.
    Cheers
  • iridebikes247
    • Dec 2011
    • 1449
    I wouldn't run 1P in your boat. Each cell will be stressed less in the 2p setup. Also if a cell ever goes bad you're less likely to kill the other pack.
    • gixx1k2
      • May 2013
      • 277
      2P gets my vote too.
      Michigan Fast Electric SAW Club
      • kevinpratt823
        • Aug 2012
        • 1361
        Most likely the 10000 is just 2-5000's connected together at the factory.
        Sent from my SCH-I535 using Tapatalk 2
        My private off road rc track
        https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
        • gixx1k2
          • May 2013
          • 277
          Probably is, just check and see before you buy.
            From an electrical standpoint it is usually better to run 1P if you have sufficient mAh capacity. There is half the wire needed between the pack and the ESC, reducing the ripple current and the resulting stress on the controller. However 1P may reduce your ability to obtain the best CG.
            • gixx1k2
              • May 2013
              • 277
              1P puts a lot more current load on the batteries and most don't like spending a fortune on batteries. When running 2P you can get away with running cheaper batteries. IMO that's a big factor in choosing.
              • Xcesive8
                • Jul 2009
                • 395
                Ok so out off the above.
                If I have sufficient mah it should be fine.
                May be harder on packs, but if I get good packs with high C should be ok.
                If in fact it is 2 5000 packs together it is wired as a pack as 6s 10,000 2p which is kinda the same thing I'm going to do but with less wiring.
                Hmmm.. Thanks for your input, much appreciated. I'll have a think about which way ill go
                • iridebikes247
                  • Dec 2011
                  • 1449
                  If they're using 2 5000 packs together, then I'd buy them. Less wiring as you said.
                    This simply isn't true. I have run 6S1S/6000 and 6S2P/3300x2 in the same boat and saw zero difference in performance or pack temperatures. Logging showed a lower ripple with 1P. The motor doesn't know the battery configuration, it places the same demands on the packs.
                    • gixx1k2
                      • May 2013
                      • 277
                      Wouldn't running 2P split the current load between the 2 packs?? Where when running 1P the current load is on just the 1 pack? Makes sense to me but then again I'm no expert.
                      • kevinpratt823
                        • Aug 2012
                        • 1361
                        It's more about the total mah available from the configuration.
                        • jj2003
                          HIGH VOLTAGE ADDICT!
                          • May 2011
                          • 1501
                          Fluid is 100% correct. The load is not determined by the batteries but by the motor. There is no motor or ESC which "see's" how many batteries you have in series or parallel, only how many in total. It cannot pull a determined amount of load from each individual battery to distribute the load. It only pulls the same load across all. Add in extra wiring and you introduce more resistance which increases ripple effect, in turn posing a threat of ESC or motor damage (i.e; overheating due to voltage spike's or amperage overload, hence the addition of cap bank's) Introducing 2p will not give you even distribution, only longer run time. However with such a large hull, 2p run on each motor CAN give you better weight distribution and a better CG. You may consider ballast if CG is a problem and you dont want to spend the cash on larger and better quality batteries such as Maxamps or Hyperion or Thunderpower.
                          "If guns cause crime, all of mine are defective"
                          45"Speedfreek
                          , Fightercat #068 ​, MyYoutube Vids
                          • madmikepags
                            • Aug 2012
                            • 1359
                            if you read his post he means 1p 10,000mah or 2p 10,000mah the mah are the same just 1p or 2p, but there is no such thing as a 10,000mah cell so the comparison is irreleveant. Any 10,000 pack is internally paralleled
                            We call ourselves the "Q"
                            • jj2003
                              • May 2011
                              • 1501
                              If running in 2p you would have to keep the wire length's almost identical. The mah doesn't matter. In 2p your just increasing the mah (run time). If your wire's from the 2nd set of batteries are longer than the first pair, there is more resistance introduced and hence more load on the second set of batteries (they would run a bit hotter than the first pair, maybe not alot but you would feel, by touch, the difference or if you measured it with a IR temp reader, you would see it). Think of it like an extension cord. If you have a device that draws alot of amp's, the longer to cord is, the hotter it will get. If it's shorter the less load it produces. Test the theory for yourself. Plug in a shop vac with a short cord, run it for 10 minute's, and then do the same with a long cord. I'd bet money on it that you'll find the longer cord is hotter than the short cord. Vehicles that have a short starter lead cable pull less amps at the starter than vehicles with a long starter lead. I've seen many a vehicle's misdiagnosed with a bad starter( showing amp draw larger than 200 amps) when it turned out to be corrosion on the existing cable, despite the length. Although in general, a longer cable will show more amp draw. Can't describe it any better than that other than testing it on your own. Make no assumption's, your own field test's will draw your best conclusion. Mine clearly showed that if I wanted more run time, I increased the mah. If I wanted less draw but better speed's, 1p was the path I took. The craft was lighter but less stable on 1p but my speeds showed increases of almost 10mph over 2p. On 2p it was more stable but the load was higher and speeds were slower. Both runs were about 3 minutes using 6s1p 5000 mah 50c config and then 6s2p 5000 mah 50c.
                              45"Speedfreek
