58 Atomik batteries? Castle 2028
  • atechbh
    • Sep 2012
    • 388
    I'm wondering about the best choice for size of batteries.
    I want to run 10s with my castle 2028 and castle 200hv esc
    Should I get 2 5s packs in 5000 or 8000 mah?
    Or other suggestions?
  • atechbh
    • Sep 2012
    • 388
    Just added this in the wrong spot. Not sure how to switch it?
    • iridebikes247
      • Dec 2011
      • 1449
      this thread will be moved to another thread. you should get 4 5s packs. This way you'll get good run time and not put a hurting on the packs.
      • atechbh
        • Sep 2012
        • 388
        Should I go 8000 mah or 5000?
        • lenny
          • Sep 2010
          • 4293
          First what is the C rating on them ?
          You should use 30c or higher cells,
          8000 would give more run time if they will fit in the hull,
          Also in less you may want to use them in a smaller boat.
          Than go with 5000.
          ? ONLY IF THEY WORK
          • iridebikes247
            • Dec 2011
            • 1449
            4 5s packs, 5000 mah you should buy. 8000 mah packs will be huge and expensive. if a cell goes bad it won't be fun.
