Hello Guys,
I will be setup up 2 - 4s 4,000 packs sin series and then put them together in parallel to achieve a 8s2p 9,000mAh power setup for my 42" boat application. I am debating wheather to go with 30c or 65c because the setup on a 30c discharge rate costs 1/3 of the setup with a 65c rate (I'll be saving around $280). Can you tell me which way should I go and why. Will it be too hard on the electronics if I go 30c? The 8s2p cell count will be moving a Turnigy AquaStar T20 3T on 730Kv configuration and later on a Proteus x524 on a 910Kv configuration. I will be running a 52mm 3 blade prop with this setup. Thank you
