Battery Temps to High. ?
  • 704Authentic
    • Nov 2012
    • 178
    After a bit of hard running on cool lake water, Temps are as follows:
    Motor 75
    ESC 80
    Batteries 125-130
    Is that normal? ... something incorrect?
    Thanks,
    AquaCraft UL-1 59mph.
    Motley Crew 61mph.
    JAE 21FE ~~~ 70 MPH Club ~~~
  • photohoward1
    • 1611
    Motor and ESC are perfect. How long did you run and what is the set-up. Batts get hotter as they approach low voltage cut-off. Best not to let bats go below 20%.
    We nee the total set-up picture to evaluate.
    • 704Authentic
      • Nov 2012
      • 178
      What's the high and low numbers for ' Happy Battery Temps.'
      6 -10 min. run times.
      AquaCraft Wildcat EP, Leopard 3650 / 2450 kv, ProBoat 60amp esc, Stilleto 1.6 x 2.5 prop. 14.4v.
      Motley Crew 61mph.
      • TristanJones
        • Oct 2012
        • 266
        50-70degC i've been told, thats for cheap chinese batteries, not sure if that matters or not.
        My 4AH would see 75degC after 5-7mind hard running, no puff ups still balance fine and run great....
        Hope that helps somehow.
        • drwayne
          • May 2008
          • 2981
          OMG that's some bad advice right there. :shock:
          75'c is terminal for lipo cells....
          Overheated cells fail, and reheat quicker.. .. before they self immolate
          'Optimal' finish temp is below 50'c ( 130f )
          There is a battery header on main forum.. go there for good solid advice.
          burn and learn.
          DocW
          • TristanJones
            • Oct 2012
            • 266
            well there ya go
            • 704Authentic
              • Nov 2012
              • 178
              Thanks guys!
              Motley Crew 61mph.
              • keithbradley
                • 3663
                That's not bad for such a long run. Judging by your temps I would guess that you are running in some pretty cold water...that's the only explanation for your very low ESC and motor temps. I would also assume that if you took ESC temps at the caps they would be significantly higher.
                I use 140F as the cut off for lipos, but I try to keep them cooler than that if possible. Doc's advice of under 130F is pretty reasonable.
                www.keithbradleyboats.com
                • 704Authentic
                  • Nov 2012
                  • 178
                  Thanks. ...better now.
                  FYI - Temps taken from all over ESC, caps were the hottest, 80.
                  Water temp 50-55 :)
                  Thanks again,
                  Motley Crew 61mph.
                  • keithbradley
                    • 3663
                    Water temp 50-55 :)
                    Thanks again,
                    In that case, it is a little abnormal for battery temps to be that much hotter than everything else. It's ok that your batteries get 125-130 F, but it is odd that the caps are 80 and the lipos are 125-130.
