Has Anyone ever used these watercooled battery coolers
  • crrcboatz
    • Jan 2009
    • 914
    I ordered 4 sets of these, 2 natural aluminum, 1 blue anodized and one red anodized. Any reason they would not work or has someone used them?? Screws and water inlets and outlets come with them too just not in the pics.
  • Rumdog
    • 6453
    why would you want to cool the lipos? It's counter-productive.
    • kevinpratt823
      • Aug 2012
      • 1361
      Huh? I was on the phone with a guy from Thunder Power the other day, discussing batteries, specifically in boats, and he basically said that lack of heat dissipation in the lipos is the limiting factor, which is why he steered me away from larger/high mah packs. I know they perform best warm, but that doesn't seem to be the problem after a few laps drawing over 200 amps.
      My private off road rc track
      https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
      • Rumdog
        • 6453
        Wow. that guy steered you in the wrong direction. If you're over heating lipos, the are inadequate for your setup, or the setup itself is faulty.
        • Doby
          KANADA RULES!
          • 7280
          Yup...Most companies have no idea about the requirements of boats...
          Grand River Marine Modellers
            • 9488
            Uh what....
            he wants you to use smaller packs
            • iamandrew
              • 577
              I think the problem was "you were on the phone to thunder power" thats like saying " I was on the phone to venom..."
              • Rumdog
                • 6453
                Did you get those for G Freak?
                • Doug Smock
                  Moderator
                  • 5272
                  If you're over heating lipos, they are inadequate for your setup, or the setup itself is faulty.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • crrcboatz
                    • Jan 2009
                    • 914
                    So ifim running say. 105* why not coolthepacks down 20* ???? Seems that would be a good thing all the way around
                    .h
                      • 9488
                      .h
                      warm packs produce more power...
                      cooling plates are a waste of cash, spend the money on better packs
                      • TheShaughnessy
                        • 1431
                        A namba straight line record holder I know actually warms his batteries up before putting them in the boat. I've also seen some testing done that showed warming the packs up before hand actually makes them run cooler over the course of the run when compared to running them from ambient temp.
                        Cooling plates are definitely working backwards. Can't believe the TP guy said to use packs with less Mah. SMH
                        • properchopper
                          rcgoatbuild@snotmail.com
                          • 6968
                          If anyone is concerned with developing better and more complex cooling apparatus to keep their components from overheating and failing, DO NOT read the following advice :
                          " The best solution for keeping temperatures in a safe operating range is found in your prop box"
                          • Darin Jordan
                            • 8335
                            There is a reason why ROAR does NOT allow you to heat your packs prior to a race... They tech them out and also impound after and tech them again.
                            Cold packs are a good way to puff them... If they are getting too hot, then your boat isn't setup correctly, and you are likely to be frying other parts as well...
                            Darin E. Jordan - Renton, WA
                            • dana
                              Banned
                              • Mar 2010
                              • 3573
                              I agree with the others, lipo cooling plates are just stupid.
                              Prop down
                              Better packs
                              Limit run times
                              Proper set up
                              All wayyy better ideas that cooling plates
