Does it matter wich side one hook up the balance lead vs where you plug in the lipo pack? Ore put another way , wich side of the balance plugs is for the first EC5 plug.?
It does not matter. All 6 power pack plugs are in parallel, as are the balance plugs. If you plan on charging multiple packs at once be sure they are all the same type ( i.e C rating, discharge rating, brand, ect) and discharged to the same point. If a individual cell is off by only a few 10's of mV from the other cells in parallel you may likely burn up the board. There is a new version to help prevent this.
I have been P charging for several years. But I just got a bit unsurten about hooking up on these boards. First time I have one, and many moons ago one had to make them you're self :-) I came to the conclusion after I posted that it will be just like the ones I have made my self, does not matter wich balance led goes were VS wich charge lead gos where. I see P RC have a bunch of parallel wires ready made, probably would be easier to hook/unhook with those than a board in the long run
