Puffed up lipos
  • hamptoncat
    lipo killer
    • Feb 2012
    • 55
    Puffed up lipos
    Ok guys,please tell me what causes lipos to puff up. It still seems to charge ok on my balance charger but it looks bad. It's a turnigy 4s 5000mah
  • driftah
    • 760
    toss it in some saltwater if its puffed its toast,complete risk to run it again.Lipos puff usually cause of an inability to supply the amps you are trying to pull.u may need to investigate the setup carefully dude.
    • hamptoncat
      lipo killer
      • Feb 2012
      • 55
      Thanks, I put this on the wrong forum, and have now been looking at the batt forum, I appreciate the info
      • JimClark
        • 5907
        thread moved
        Billy Graham
        • egneg
          • 4670
          Check them very close. The shrink on the Turnigy's will puff from heat but not the cells. I have some that appear to be slightly puffed but are just fine and have been using them and have charged them several times.
          IMPBA 20481S D-12
          • hamptoncat
            lipo killer
            • Feb 2012
            • 55
            I will look closely when I get home Friday. Thanks
            • Cutch
              • Jan 2011
              • 31
              I have a pair of Turnigy 3 cell 5000mAh batteries that puffed up over winter last year. Feels like the shrink is under pressure but the cells aren't puffed up. They seem to charge OK but I don't know if it it's safe to run them. Don't want to blow up the boat.
              • lenny
                • Sep 2010
                • 4294
                Hi,
                Can you post some pictures of them ?
                May be it is just one cell that is puffed in each pack.
                If so, They could be made into 2s packs or something,
                Or used for parts may be.
                ? ONLY IF THEY WORK
                • eocv
                  • Aug 2012
                  • 24
                  Like egnef said, the shrink will make it look puffed but just look at it from the back end where you can see the stack of cells. If they look like an oval, keep a close eye on them. You don't want this to happen, my buddy took a chance and almost lost his boat. ImageUploadedByTapatalk1353632767.591617.jpg
                  • eocv
                    • Aug 2012
                    • 24
                    • MarkF
                      dinogylipos.com
                      • Mar 2008
                      • 979
                      Puffed batteries usually feel soft and squishy. I've had pleanty of puffed Thunderpowers that charged and ballanced just fine and I had no problems running them. The key is making sure they still ballance. Also make sure there not to hot after a run. Thats another sign there junk and shouldn't be used.
                      Mark
                      • capnswanny
                        • Feb 2012
                        • 817
                        Sorry to hijack...I have a seriously puffed old Dynamite 4s to dispose of. Its been sitting outside on gravel, undercover for a month now because I don't want to burn down my house. Is putting it in a bucket of seawater the way to make it safe to dispose at the recycle center?
                        Thanks,
                        Corey
                        This is NOT a toy?!?
                          Yes.
