Wiring Harness to Convert From 2P to 2S
  • D&D
    • Aug 2009
    • 185
    I am currently running a Castle 180HV controller which come setup with two sets of battery wires for a 2P setup, I would like to try running a 2S setup. Has anyone come up with a good idea for a wiring harness to convert the Castle 180HV to temporary 2S setup?
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    Home made 5.5 mm connector adapter...
    Canada
    • TheShaughnessy
      • 1431
      You should be able to just cap off a lead from each connector. If its hooked up I parallel the circuit will be complete when you hook up the first batt
      • LiPo Power
        • May 2009
        • 3186
        Right.
        Both, red and both black wires are connected together on the main board inside....
        Canada
        • D&D
          • Aug 2009
          • 185
          So it appears that you soldered three 5.5 connectors together and then covered them with shrink tubing. I assume that this is to solve the problem of the two sets of wires from the Castle 180HV, or do you use the same setup to connect two batteries together? It seems to me, from when I started to think about trying 2S versus 2P, that there would be an auful lot of connectors/connections which could setup negative resistance????? I am an old nitro guy, I can build the boat, but electrics are still like a mystry to me.
          • dana
            Banned
            • Mar 2010
            • 3573
            Just plug in to a set of wires and cap the other two off. Keep it simple
            • LiPo Power
              • May 2009
              • 3186
              Bingo!!!
              Canada
              • TheShaughnessy
                • 1431
                Or just run 2p and enjoy less voltage sag.
