I just bought new lipo sky lipo battiers and when i put them on the charger my charger reads IN VOL ERR why is this. Do i need to charge at a low voltage what im I doing wrong
New lipo battery wont take a charge
Unless you have a plug in voltage checker (checks each cell) one of the cells might be too low or too high. Try cycling the batt in balance mode first or discharge mode. I don't see that Steve sells them but you need to get one of these Value Hobby Sells them 3.99 http://www.valuehobby.com/lipo-volta...rm-tester.html shipping is only 3.99 too.Traxxas Blast,Spartan,Villian. Aquacraft Revolt,SuperVee, UL-1, Wildcat, Gunslinger27,Atlantic Harbor Tug, Bristol Bay trawler.Cajun Cmd. ProBoat Widowmaker,BJ26/29,Fastech,Stiletto,Volere,Mystic,Impulse 31.Deltaforce 29" Mono. 37" Mystic FC , Atlantic YachtComment
What mah and cell count is the Lipo? What voltage does it read now as well?? Do you have a tester for each cell.................if not a standard voltage meter with the metal prongs will work to test each cell thru the balance connector. I can help you if you answer these questions.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
brand new battiers wont take a charge
I bought 4 new sky lipo battery 5000mah 7.4v 2 cell. Right out of the box they have 7.6 volts, When hooked up to the charger. I get a IN VOL ERR message. Si I lowered to amps to on the charger down to 0.5a and it will charge at that rate. Ive got one of the batterys up to 7.75 volts and tried to put in on the charger at 4.0 amps and i still get the same message IN VOL ERR some one pointy me the right directionComment
If you have a voltmeter you can CAREFULLY put it on the metal pins on the balance connector, do you understand the pinouts on a balance connector?
Check to make sure you aren't setting it on 1S or 3S (or some other cell count), what charger do you have?Bling rocket 32" T600 1400kv on 6S, Twin Lynx 3126 2200kv on 4SComment
Bingo!! When I overload my wall outlet and use three or four chargers, at some point one of them sags enough to give that error. What else is plugged in there..............try another wall socket.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
What charger is it?
What are you using for a power supply?
If I plug my Hyperion Dou into the cig lighter plug near the rear hatch in my SUV I get that error, but if I hook it directly to the battery it works fine. Mostly if I try charging 2 4s packs at a higher rate. Had it happen on the Venom Pro and had a loose connection into the charger from the power supply.Comment
Its still the voltage "IN" to the charger...................... Does your charger have a seperate power supply?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
It's not just boats. I have the Traxxas Bandit, E-maxx, Summit, Ken Block Gymkhana. Kyosho Dark Impact, Tamia Fox ,Losi Mini Desert Truck, RedCat Lightning EPX. And I just got into R/C 3 years ago. The OT's gotta go somewhere. LOLTraxxas Blast,Spartan,Villian. Aquacraft Revolt,SuperVee, UL-1, Wildcat, Gunslinger27,Atlantic Harbor Tug, Bristol Bay trawler.Cajun Cmd. ProBoat Widowmaker,BJ26/29,Fastech,Stiletto,Volere,Mystic,Impulse 31.Deltaforce 29" Mono. 37" Mystic FC , Atlantic YachtComment
