6S 5000mA pack fit in Genesis/FCDaytona sponson?
  • Prop-a-Gator
    • Feb 2012
    • 163
    Anyone know if a Zippy/Turnigy 6S 5000mA pack will fit into a 37" Daytona/Genesis sponson without modifying the hatch lip? The 4S 5000 pack I have is a snug fit - without a battery tray. Curious if anyone's tried it.
    Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
  • PeterKnell
    • Mar 2012
    • 28
    I can say the Turnigy 5000mah fits definitely but i have never tryed the Zippys
    • iamandrew
      • 577
      I have the 5000MAH Flightmax 5S packs and they are a tight fit but do fit in.
      Most people who use 6S on the genesis just do 3S in each hull in series
      • JonD
        • Jun 2011
        • 129
        This guy has 6S 5000mah Turnegy in each sponson
        http://forums.offshoreelectrics.com/...ed-help-me-out
        See photo in first post in the thread.
        Jon
        • madmorgan
          Banned
          • Jun 2011
          • 152
          note hes running long packs which means they arent as thick
          • Prop-a-Gator
            • Feb 2012
            • 163
            Thanks for the responses, guys.
            @madmorgan, yeah, I noticed that too. Just based on how tight my 4s pack is, I suspected it could be an issue. My 4s pack fits easily if I stand it lengthwise against the side of the tunnel rather than lay it flat in the sponson. The problem is - according to the dims on HK - the 6s pack is as thick as the 4s is wide. Maybe i'll just go with 2x3s in series and live with short run times. It would be my high speed drip anyway with a 1760 kv motor.
            • Prop-a-Gator
              • Feb 2012
              • 163
              *setup - not "drip"
              Damn autocorrect!
              • izcain
                • Mar 2012
                • 274
                I run a CF Daytona with two 3s zippys in series and they fit nice but I do of course wish the run times were longer but instead I will just keep buying batteries. The more batts the more fun time lol
                • QST4IT
                  • 12
                  They should fit fine directly on the bottom. I ran (2)6S Turnigy 4.5s in mine with no problems fitting. If I remember right seemed like I was seeing 30 min + run times, was great.
                  Ken
                  Currently running, Genesis lepoard 4082 1500kv, 180amp seaking ESC, 2ea Turnigy 6S,P-4500ma. Turning a grimRacer 40x57-65+Mph
                  • Prop-a-Gator
                    • Feb 2012
                    • 163
                    Thanks Ken. I've been running two 3S. I was also a little worried two 6S 4-5ah would be too heavy. Was it a problem for your Genesis?
                    • QST4IT
                      • 12
                      No problem, actually I like the extra weight myself Helps keep the boat planted, as long as its balanced right. Had some minor stressing mainly under the motor mounts tourque related.I added CF to entire bottom and 2 layers glass tape to the mounts when I re-installed them. here is link to short vid not that great but anyways.
                      • pappystoys
                        • May 2012
                        • 13
                        Just wondering if you upgraded your shaft? I just bought the genesis and put the 180amp seeking in with the stock motor. All of my buddies are running spartans with lips and are killing me. I may run the same setup as you. Can you help me out by any chance, just telling me what I need to get/do. Thank you
                        http://www.youtube.com/watch?v=63HxCzRTeLE
                        • QST4IT
                          • 12
                          Pappy,
                          I did upgrade the shaft, I put a 3\16 flex in with 3\\16 prop shaft, I ended up drilling the strut slightly to fit a bushing in for the propshaft. Has done well so far the boat has awesome holeshot with massive tourque roll on launch even with the big 6S packs in the sponsons, so the shaft definately gets a hard work out.
