got a 1250mah 20C 3S rhino pack yesterday and threw it on my twin airboat for about 3 minutes today, it's drawing about 20A constant.
I had not charged the pack and hit the cutoff pretty quickly and the battery was reasonably warm (nothing to be worried about, no puffing)
plugged it into my accucel 6 on balance mode and it showed connection break charging at 1.2A
I plugged in a 2S pack quickly on charge at 1A and it worked fine, tried a 3S pack on 4A and it worked fine.
I then plugged a few Led's into the positive of the balance plug and using each negative I got the led's to light up, put a voltmeter to the main plug (deans ripoff from hk) and it moved the needle, the setting was on 250VDC and it's analog so i didn't get a good reading but I know the pack has voltage, the main plug lit up the LED's aswell.
all the connections in the charger (opened it up) look fine, the second pin of the JST female (first negative) is not connected to anything inside the charger, it doesn't look like it was meant to and i have used the 3S jst plug to charge before (and balance). all the others are connected to the second main solder joint on the main charger PCB, wired in parallel, is it the pack or the charger that is broken and can it be fixed?
