My batteries after a run are at almost 200 degrees. Here is my setup in a twin configuration:
Red Leopard LBP3650-B/3.5D, 86A, max, 15V max, 1300W max, 3900KV, 0.0075 internal resistance, 2.7A no load, 4 pole
Turnigy Marine 120A ESC, Constant Current: 120A, Burst Current: 240A, Resistance: .0007ohm, Battery: 2-6S Lipoly, BEC: 3A/6v, Motor Type: Sensorless Brushless, *Speed: 100,000+rpm (2 Pole)
Batteries Venom 3000mah, 7.2V, NIMH
These motors are fitted to Aquacraft EP1 motors, are water cooled and running cool. The ESCs are running cool with no water cooling. I am using soldered Dean Ultra plugs from batteries to ESC and standard crimped automotive type bullet connectors to the motor. Due to the distance from the ESC to the motor, an extension of 6 inches is added to the ESC and another extension to the motor something like this:
Battery()====ESC===[]Transom[]=====||====Motor
() = Deans Ultra [] = Automotive crimp bullets 5mm || = 5mm gold soldered connectors
All this in a 34 inch Aeromarine Titan.
Thanks for any insight.
BBQSteve
BBQSteve
