lipo cutoff mod
  • 1truckerdan
    • Aug 2011
    • 329
    lipo cutoff mod
    Hey I figured out a way to use a 2s novak smart-stop on any 2s or more lipo pack.
    I talked to the tech at novak and my idea will work perfectly!The current draw is small enough to work without issues.
    What I did is soldered up the power in wires of the lipo cutoff to the outer 2 pins of a 3 pin male connector and removed the the middle pin.SV27 015.jpgSV27 018.jpgSV27 014.jpg
    Now I can plug it into the balance leads of any pack 2s and up and it will cutoff when the 2 cells (that it is plugged into) reach6.4v ( 3.2v per cell).
    I can use it on any setup I need and switch it to another without any modifications ....just plug it in.
    Make sure of the polarity when you plug it in to the balance plugs.
    It will work on any of the 2 cells (in series)in the pack.
    I thought I would share this here.
    Daniel
    When you know it all.......you never will learn anything new
