My 3 yr old deep cycle battery is history; need to buy another battery - wondering which is better. Need to hold voltage up the highest; my Hyperion chargers kick out a "low input voltage" error message when the voltage of the storage battery drops some. I seem to remember that there's a way to set the LV threshold on the Hyperions but can't find the info. Anyone ?
"Deep Cycle" or "Starting" battery for lakeside charging; which is better ?
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoTags: None -
What about a gel cell like an Optima? Its a pricey buy...
The yellow tops would work also.
You might be able to pick one up on craigs list local. Also many of the car audio batteries would work- sealed gel cell types.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
You could run the chargers on 2 deep cycle batteries in series (24 volts). It'll lower your amp draw and might help your Hyperions run cooler by not having to step up the voltage as much.
Twice as much weight to lug around though...Comment
Thanks for the suggestions, But... Optimas are out of my price range .... two deep cycle batteries too, plus I have to carry my battery up a flight of stairs to recharge it so two batteries would be tough. A jump pack has a small overall capacity....not sure what a dry cell is. I'm still looking to find out the difference between a Deep Cycle and Starting battery - I can get either for less than $ 100 - just would like to know what the difference is between them & which would make a better Lakeside battery.
Thoughts ? John ??2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
A deep-cycle lead-acid battery is designed to be regularly deeply discharged using most of its capacity. In contrast, starter batteries (e.g. most automotive batteries) are designed to deliver short, high current burst for cranking the engine, and to be frequently discharged of only a very small part of their capacity.
Found this online, hope it helps.
In my full size boat I have a battery that's a combination heavy duty marine starting/deep cycle battery.
Mark
MarkComment
Tony,
These go on sale even lower sometimes, I've seen them and 98.99 before. 800 watts should be more then enough power and I doubt it"ll consume much gas.
http://www.harborfreight.com/engines...tor-66619.html.
If you left it on all day you could expect about 5 hours for a gallon of gas a 3.60-3.99 a gallon plus oil. I'm not sure if charging a battery is costing as much or not.
here are the specs
Name 800 Rated Watts/900 Max Watts Portable Generator
SKU 66619
Brand Chicago Electric Generators
Run Time 5 hrs at 50% load
Fuel Shut Off Fuel Shut Off
Mounting Type Horizontal
Output Watts 800
Output Voltage 120
Output Amps 20
Decibel Level 91
Outlet Receptacles 1
Shipping Volume 1.867
Certifications/Approvals EPA and CARB
RPM Rated 3600
Fuel Tank Capacity 1.1 gal
Start Type Recoil
Max Output Watts 900
Horsepower 2
Manufacturer Warranty DetailComment
Stinger9D9 and Jim Clark both have valid arguments. A deep cycle battery will allow deeper discharges without damage. That's why they are used in solar power applications as well as golf carts and trolling motor use. And two of them (24v) will be easier on the charger (but more weight to tote). So the best solution might be two small deep cycle batteries. BTW, that deep cycle battery should have given you another couple years of service IMO, - were you charging it back fully at the end of every session and checking the water levels?Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
Stinger9D9 and Jim Clark both have valid arguments. A deep cycle battery will allow deeper discharges without damage. That's why they are used in solar power applications as well as golf carts and trolling motor use. And two of them (24v) will be easier on the charger (but more weight to tote). So the best solution might be two small deep cycle batteries. BTW, that deep cycle battery should have given you another couple years of service IMO, - were you charging it back fully at the end of every session and checking the water levels?2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Go and buy an Inverter Drive Generator, lots of companys make them now and the prices are well under $1000.00 I am seriously looking into buying one now. Costco canada has a 2000 watt inverter gen for $500.00 and I just heard it run WITH a load on it, Very Quiet !There is no replacement for displacement, I guess I just have to Buzz it higher!Comment
I've prematurely ruined a deep cycle battery or two in the past. Isn't that how you learn?! Costly education. Another solution might be to get a solar panel and let it charge the battery. A single panel charger won't overcharge a deep cycle - you can leave it hooked up until you need it. Of course you'd need a secure storage location. Times being what they are, it might grow legs and walk away.Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
I've prematurely ruined a deep cycle battery or two in the past. Isn't that how you learn?! Costly education. Another solution might be to get a solar panel and let it charge the battery. A single panel charger won't overcharge a deep cycle - you can leave it hooked up until you need it. Of course you'd need a secure storage location. Times being what they are, it might grow legs and walk away.Comment
I've prematurely ruined a deep cycle battery or two in the past. Isn't that how you learn?! Costly education. Another solution might be to get a solar panel and let it charge the battery. A single panel charger won't overcharge a deep cycle - you can leave it hooked up until you need it. Of course you'd need a secure storage location. Times being what they are, it might grow legs and walk away., but I feel a little better knowing that I'm not the only one to mishandle a deep cycle battery. Looks like I'll cough up for a nice new battery & keep up the maintenence. I do like the solar panel idea, but security is an issue as you pointed out.
