Best Charger Today-Anything Changed?
  • sanyijr
    • 376
    Here is my situation:
    Seems like this topic has not been visited recently.
    So, I have a Triton JR setup for parallel charging. Yes, only 50 watts so charging my 5 AH batteries takes.....longer than it should. But 2 chagers would be even better, right?
    So has anyhting changed in the "best Charger" catagory? I would love a 150-200 watt or so charger like the B6 or Hyperion 0720. I have a PC power setup already going. Willing to go $200. Do NOT want China made knock off. But is seems like there is a ton to choose from.
    What about online stores to buy from? Any recommendations.
    Thanks Guys.
    Just thought i would revisit this issue before potentially throwing out $200 oh garbage, you know?!?!
  • GP73
    • 544
    Hyperion EOS 0720I DUO here on OSE:
    http://www.offshoreelectrics.com/pro...=emp-EOS720DUO
    or 1420I
    http://www.offshoreelectrics.com/pro...d=emp-eos1420I
    • Chilli
      • Jan 2008
      • 3070
      Hyperion!!!
      If $200 was your limit, I would keep an eye on ebay and snag a Hyperion Duo. Even the older Duo II's are great chargers.
      If you can go a little higher, $250 for a new Super Duo that GP73 linked is a great price!
      Mike Chirillo
      www.capitolrcmodelboats.com
        http://forums.offshoreelectrics.com/...hlight=charger
        • sanyijr
          • 376
          Bit the bullet! 720 Duo is on its way....
          • GP73
            • 544
            Just got mine from OSE (Thanks Steve you're DA MAN!)
            Testing it now, just one word: AWESOME.
            • Chilli
              • Jan 2008
              • 3070
              You guys won't regret it.
              Mike Chirillo
              • GP73
                • 544
                Stock is now zero.... they went fast!
                Steve where is my advertising cut?
                • sanyijr
                  • 376
                  Got the 720Duo.... Charged 20 4000 and 5000 mah batteries over the weekend..... Charger ROCKS!!!
                  Thanks for the advice...
                  Now supply power is the weak link.....
                  • Mieciu
                    • Feb 2010
                    • 21
                    iCharger 106B+ has all you need including measuring internal resistance. max 6S max 250W for $80 @ hk
                    __________________________________________
                    http://www.youtube.com/user/tygrysiek82
                    • Doug Doty
                      • Sep 2010
                      • 12
                      Can I ask why I did not see the FMA power lab discussed here ?? I have found it extremely popular with the large scale heli guys and it is topping my list of future purchases.????
                      • sanyijr
                        • 376
                        Doug,
                        I guess is that the FMA power lab was not discussed because you hadn't brought it up earlier. But as you put it "it is topping my list of future purchases"...Once I research it and I have the cash.
                        • sailr
                          • Nov 2007
                          • 6927
                          I use two 47A power supplies in series from www.feathermerchantrc.com to drive my Hyperion 720duo. That gives the 24V necessary to charge two big packs at a time up to 20A charge rate on 5000mAh packs. The Power Supplies are a true bargain. $90 for the pair including shipping! There is a thread on RC groups about them. You have to remove the ground on one of them. Not a big deal.
                          I fit the 720 duo, the two power supplies, an Xtrema charger, and two smaller TP chargers all in one of those double transmitter cases. The power supplies are enough to drive all of the chargers at the same time. I have 24Vand 12V taps. If interested, I'll take some pics and post here.
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • Doug Doty
                            • Sep 2010
                            • 12
                            I would like to see your setup, I am wanting to do this as well but undecided on chargers.
                            • sailr
                              • Nov 2007
                              • 6927
                              Charge system in an attache case.
                              P1000548.jpgP1000549.jpgP1000550.jpgP1000551.jpgP1000552.jpgHere's some pics
                              Mini Cat Racing USA
