Venom 2s 5000mah 50-100c (series for 4s)
Speed: 36.5mph
Batt 1: 127F
Batt 2: 130F
Motor: 119F
ESC: 117F
Volts: Max - 16.76vdc / Min - 14.13vdc
Amps: Max 82.90
Loaded Rpm: Averaged between 21,000 - 23,000
Watts: Max 1252.62
After run:
Batt 1: 3.80vdc,3.81vdc
Batt 2: 3.80vdc, 3.80vdc
* Out of all the batts tested today the Venom's had the largest drop in voltage, highest temp reading per batts while yielding the higher price tag. Time will tell on these. They are new and may need some time to stretch a little and settle in. I am sure the heat is related to the hardcase lipos.
Speed: 36.5mph
Batt 1: 127F
Batt 2: 130F
Motor: 119F
ESC: 117F
Amps: Max 82.90
Watts: Max 1252.62
After run:
And hey, if Im wrong, Im wrong and Ill ship it back to you at your expense.
