Turnigy jst balance lead problem
  • jamespl
    • 742
    One of the wires has come out of the jst balance plug on my 5800 2s turnigy lipo and I can't get it back in. My question is can I get a replacement plug or is it ok to use and charge the battery without balancing it? I usually balance every charge.
  • SweetZ28
    • 1322
    No always balance charge!
    there should be a little tab on the connector on the end of the wire that you can slightly bend up and then push it back into the plastic balance plug and it should hold in place again like new.
    they go in a certain way look at the ones in the plug and put the one that is out back in the same way.
    WWW.PPRSLOTS.COM
    • jamespl
      • 742
      I tried that, i managed to get the clip that holds the wire in out of the plug and put the wire back on it but it has come out again so I think it's had it, might just have to replace the battery then.
      • SweetZ28
        • 1322
        are you saying the wire pulled out of the metal connector?
        If so solder it on to the end of the connector and put it back in the plug and then put a nice good thick coat of goop shoe goo over it and the end of the plug and let it dry and it will be good as new.
        WWW.PPRSLOTS.COM
