I am trying to find information on how to tell what motor to pair with what esc & what batteries etc.......
Calculations Help Needed
Your question has a lot of variables.
what hull, race or play ?Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @ -
Well one I'm working on is the 17" mini hydro I have for play.
I'm just trying to figure out how to understand the motor specs then translate those to figure out the esc needed and batteries.
Also since you mentioned it how a hull effects the process.
Obviously a larger boat will need a larger motor that uses more power.OSE GIFTING ELF
HAPPY HOLIDAYS!!Comment
One motor I am looking at is
The other one is
I am trying to figure out if a 35amp esc will be ok with the setups or should I go bigger.
I believe with the 3000kv I should be able to run a little larger prop correct??
The 4800kv motor says 11volts???Last edited by monojeff; 03-16-2011, 09:25 PM.OSE GIFTING ELF
The other one is
The 4800kv motor says 11volts???Not advisable !
For a 17" hydro a 35A esc may be enough, I would run a 60A just to be safe but there are far better qualified hydro runners here than me. I am a Cat and rigger typeSee it....find the photos.....sketch it it....build it........with woodComment
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
Thinking one of these motors will be a good choice possibly instead of the others
3500kv outrunner
http://www.hobbyking.com/hobbyking/s...dProduct=11178
4400kv outrunner
http://www.hobbyking.com/hobbyking/s...dProduct=11177
I would obviously need to jump the esc up to the 60amp
or I could even go up to the 90amp esc
Thoughts?? 2-3SOSE GIFTING ELF
