Turnigy vs hyperion
Thanks... Now I need to figure out which ones to buy and snag a set while I can.
Thanks for the info on the deal. At only a few bucks over Turnigy and knowing its a name we can trust its worth it to buy (to me from a newb standpoint).42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
I have both and like both. They all perform very well. I was impressed, or actually surprised how the so called cheapos keep their capacity and low IR over nearly too years of heavy use. So far HK has saved me hundreds of bucks, making my big electric projects possible.
The Hyperion G3s are better finished, better packaged.
The Turnigy performs as well as if not better than the G3. You do need to redo the plug though for its solder job was really not as good. Im comfortable (and good at) soldering, so that's zero problem.
The one thing that put me of the Turnigy packs the few time i have ordered them from HK i always get one bad pack in the order , just recived an order of 4 packs & yep one pack was puffed & showing no voltage , now its going to cost me as much as the pack did to send it back for warranty , im better off cutting my losses & bining the bad pack ... And HK state they check every battery before they send them , what a joke !!!!!!UL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2PComment
when i looked at the link with the hyperions i saw balancing leads and another that looks like the tamiya plugs. i dont know if they are but the poster is not talking about the balancing leads. but they could be receiver packs too.Comment
He's not "seeing" things................here's the pic of the Hyperion 20c 7.4v with a tamiya/Molex connector.Attached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Heres how I rate Lipos that I have tried as far as value as well as performance. I can only vouch for these brands as these are the only ones I own. I started out with Turnigy and though well maybe the higher priced packs are better. Boy was I wrong to some degree. While some does provide a small advantage in the peformance department IMO it does not justify the price especially since I'm not out to set records or win any competitions.
1. Turnigy/Zippy
2. Hyperion
3. Voltz
4. Flight Power
5. Blue Lipo ( I got this used from a friend and did not know it's history. )If all of your wishes are granted, many of your dreams will be destroyed!Comment
1. Turnigy/Zippy
2. Hyperion
3. Voltz
4. Flight Power
5. Blue Lipo ( I got this used from a friend and did not know it's history. )OSE GIFTING ELF
HAPPY HOLIDAYS!!Comment
I have not used the Turnigy Nano's Although they should be similar to the Hyperions.If all of your wishes are granted, many of your dreams will be destroyed!Comment
I have heard some good things about the Polyquests...............here's a couple links, Hobbyking carries 7 pages worth of them................some are quite expensive but these look like a bargain:
http://www.hobbyking.com/hobbyking/s...idProduct=7162
http://www.hobbyking.com/hobbyking/s...dProduct=11255NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
