is my 2s pack junk?
  • dana
    Banned
    • Mar 2010
    • 3573
    is my 2s pack junk?
    pack is a venom 2s1p 5000 mah. it has been charging weird lately. individual cell voltage is all over the place. 1 cell reads over 4.20 at points and the other jumps all over the place. initialy when first charging after a run the cells reads the exact same voltage, but after charging for a while they do some funny stuff. kinda nervous.plus the chrager never beeps for a full charge like the other pack, it just stays arounf 0.4 amps and never seems to top off. anyone know if this thing is crap? it seems to be getting worse after every run. also is it ok to run 5000 mah and a 5400 mah packs together? i have another lipo that is good but different mah. thanks
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    Please do not run 5000 with 5400, must much the mAh...
    Take your liPo off the charger and just plug in to ballancer and leave it for a while...
    Are you charging using CHARGE mode or Balancing mode? What charger?
    Robert
    Canada
    • dana
      Banned
      • Mar 2010
      • 3573
      thunder ac6 charger. i am balance charging yes. what does leaving it plugged into the balance port do? should i charge at a lower amperage?
      • LiPo Power
        • May 2009
        • 3186
        So if you Balance charge them, how long do you charge them for?
        Balance charging sometimes takes long time....
        In the past, after a straight charging I would take it off the charger and just plug in to the balancer for a while to let the balancer do its job correcting any voltage difference issues...
        Canada
        • dana
          Banned
          • Mar 2010
          • 3573
          usually takes about an hour to balance charge them give or take. charger has built in balancer so if i disconnect leads charger says "connection break" i dunno i can get it to charge to 4.20 per cell but never seems to "full charge".
          • LiPo Power
            • May 2009
            • 3186
            On the charger menu, can you just select straight charging, no balance charging?
            If yes, than you shoud not need to plug your balancing wires at all to charger and still be able to charge your lipo much faster....
            Canada
