Open Connection
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1679
    Open Connection
    I have a battery that I bought used. If you check the pack voltage with a volt meter it shows the pack voltage. When I conect it to my LBA-10 balancer it reads as open connection (four flashes). Thinking it's the balance taps I tried it without the balancer. It will charge for a couple of seconds and then read open circuit. What could be going on here or is this pack junk?
  • m4a1usr
    Fast Electric Addict
    • 2038
    Are you going right to the LBA-10 connection with your pack or are you going to a 1-6S multi pack adapter? I had something similar when I was using the JST to PolyQuest adapter. I ended up buying a bunch of 6S connectors installing them in my packs and just going straight into my LBA-10. Now I dont need an "in between" adapter. I plug my packs right into the balancer. And I dont get errors anymore. It does require you to reconfigure the order of the pins on your pack balance tap.
    John
    Change is the one Constant
    • BakedMopar
      No Mo Slipah
      • Sep 2009
      • 1679
      no balance board. It was just a bacd pack.
      See this thread http://forums.offshoreelectrics.com/...ad.php?t=18131
      • 785boats
        Wet Track Racing
        • Nov 2008
        • 3169
        Do you get a cell voltage reading on each pair of pins in the balance tap, ie pins 1-2, 2-3, 3-4, 4-5 etc?
        If one of the pairs gives no reading you may have a broken balance tap wire on the pack tabs.
        The balancer would see that as an open circuit. And when you disconnect the balance tap plug it would also give you the open circuit message.
        Cheers.
        Paul.
