Is this battery shot?
  • Visual Perfection
    • May 2010
    • 312
    Hey guys,
    Just bought 3 Lipos (2s 30c 5000mah) and upon arival I tested all 3 of them.
    One had 7.35 volts
    One had 7.65 volts
    However the 3rd one has 3.49 volts : (
    I am assuming this means either:
    a.) one cell is bad
    b.) each cell only has 1.25 volts in it which means the pack is shot?
    Any insight on this would be great, maybe I am wrong?
    Thanks guys!
    The Speeders *PB SW 26 BL *PB Formula FASTech
    The Cruiser *CBM Marlin Cruiser
    The Pool Toys *Proboat Mini-C (x2)
  • johnf
    • Dec 2009
    • 1078
    How did you test them? My charger will show individual cell voltage, which may help in your case. But, if that is the voltage for the total pack, doesn't sound good.
    Catching Air!
    • Visual Perfection
      • May 2010
      • 312
      I used a digital multimeter to test them, same way I have test all my batteries.
      I don't have a lipo charger yet. (bought lipos first, getting charger for my B-day on the 11th) so I can't check it with the charger until I have it.
      If I can't balance charge it back to life the seller will make things right so I am not worried about that at all, just a little bummed I will have one less Lipo.
      I assume best way to do this is once I get the charger, check to see what each cell has in it, and if it shows one cell dead then it is shot? Or If it shows both cells really low, I can attempt to balance charge it and see if it comes back to life?
      Thanks for any help!
      • johnf
        • Dec 2009
        • 1078
        If your multimeter has sharp enough tips on the prongs, you may be able to test straight from the balance tab contacts.
        Catching Air!
        • Visual Perfection
          • May 2010
          • 312
          hmm.. good point. I think I will try that. There is a red, blue, and black wire on the balance tab...which is the positive for each cell, which is negative.
          I just don't want to short anything!
          • johnf
            • Dec 2009
            • 1078
            I would imagine black is negative, and the other two are the positives for each cell. Better wait for a lipo expert though. Wouldn't want you doing any damage because of me. haha
            Catching Air!
            • SweetZ28
              • 1322
              use your meter put black probe on black wire and red on the next wire over see voltage.
              then put the black prob on the second wire after the first black wire and then put the red prob from meter on last wire and see voltage.
              this should show each cells voltage
              WWW.PPRSLOTS.COM
              • GeoVW72
                • Jun 2010
                • 258
                you will not short anything, a digital multi-meter can read negative voltage. just be careful not to make contact across the probes and make a short through them. even if the pack is low you may still be able to bring it back if the cells do not fall too far out of balance.
                Team Boca Bearings
                S&G Design
                • Visual Perfection
                  • May 2010
                  • 312
                  Ok just tested the cells.
                  First cell has 3.24 volts in it
                  Second cell has .25 volts in it
                  Which makes sense why I am getting 3.49 volts when I test the positive and negative leads lol.
                  With that said, is it even possible to bring it back to normal...or is it going to be a no go for this pack?
                  • johnf
                    • Dec 2009
                    • 1078
                    I'd be hesitant to try and save that, especially if the seller is willing to make things right.
                    Catching Air!
                    • SweetZ28
                      • 1322
                      looks like a gonner.
                      WWW.PPRSLOTS.COM
                      • Visual Perfection
                        • May 2010
                        • 312
                        How would you even go about saving it if you did? Just plug it in and balance charge it very slowly and the charger/balancer would attempt to even them out?
                        Just would like to know as Yes the seller will make it right, but he has asked to see if it is possible to bring it back to life first, and I would like to at least try.
                        Will it be dangerous to do this?
                        I know it is probably gone, but at least giving it a try would absolutely confirm that.
                        Thanks again guys!
                        • johnf
                          • Dec 2009
                          • 1078
                          I'd search the forum for people who have resurrected excessively drained cells. I don't know the best path to bringing them back. Was just advising that the voltage that cell is at is considered dead from what i've read.
                          Catching Air!
                          • bustitup
                            • Aug 2008
                            • 3071
                            Just so you know the whole story...I am the one who sold him two brand new never used xps 2s 5000mah 30c/50c lipos...I paid $60 each for these and I sold them to him for $70 for both batts...he asked if I had one more lipo I said yes but it was used and he offered me $20 and I said ok and shipped all three for $90
                            he told me he had issues with the used one not being balanced so I asked if he would try to ballance charge it before I return his $20 and if it didnt work I would make things right..(give him $20 refund)
                            here is the exact product
                            and here is a thread on the review of XPS lipo's.......they are not junk batts
                            Nick if you dont want to try to balance charge it..... just say so and I will return your $20 NOW
                            • Visual Perfection
                              • May 2010
                              • 312
                              No worries buddy, I was just trying to see if I could indeed bring it back to help you out so you wouldn't have to refund me. Looks like it isn't going to happen though.
                              Just so everyone is clear now that you posted....Bustitup is a great seller and I would not be hesitant to purchase from him again!
