Question on Storing Lipos
  • Visual Perfection
    • May 2010
    • 312
    I just bought some used 2s 4900mah 20c Lipos and the previous owner shipped them to me charged and balanced.
    I REALLY want to test them out in my Shockwave 26 brushless however I do not have my charger/balancer yet.
    Will it be okay to use them for like 5 minutes each or less (stop use well before LVC kicks in) and then store them without charging for a couple weeks while I wait for my charger? What if I run them down to the LVC?
    Just dont want to do something wrong since I am completely new to Lipos and would hate to ruin them before I can fully enjoy them so trying to find out how they can be stored for a few weeks at a time.
    Thanks!
    The Speeders *PB SW 26 BL *PB Formula FASTech
    The Cruiser *CBM Marlin Cruiser
    The Pool Toys *Proboat Mini-C (x2)
  • RaceMechaniX
    • Sep 2007
    • 2831
    NOOOOOOOOOOOOOO Hold off and wait till you have a charger and balancer.
    Lipo's need to be stored around 50~60% SOC to keep them healthy. Leaving them near their lower limit will detiorate them bad especially if left alone for weeks.
    Tyler
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • Visual Perfection
      • May 2010
      • 312
      well crap...that means I cant even see if they work for a few weeks. 20 days to be more exact..
      However, after reading what you just said...If they give 10 minutes of run time, and they are now fully charged...why is 2-3 minutes going to hurt..that would bring it down to 70-80% so they would be stored just fine wouldn't they?
      • RaceMechaniX
        • Sep 2007
        • 2831
        Do so at your own risk. Are you certain the batteries were fully charged and not just "50% store charged"? You can use a multimeter to check the pack voltage, but still I would hold off on running the boat till you have a charger and balancer. For a 2S pack you can pick up a cheap balancing charger under $50.
        Tyler Garrard
        • Visual Perfection
          • May 2010
          • 312
          Yup I have a charger already picked out..a Thunder AC6...I asked for it as a b-day gift though thats why I have to wait 20 days lol
          I just tested them and am getting 8.30 on one and 8.28 on the other... what should it read if fully charged?
          • RaceMechaniX
            • Sep 2007
            • 2831
            Early B-day present then! Fully Charged should be around 4.2V/cell, so they are reasonably full.
            Tyler Garrard
            • Visual Perfection
              • May 2010
              • 312
              and I dont want to run them below 3.3 volts ever right? so 6.6volts for a 2s pack..I will have to see what the LVC is set for in my shockwave
              • RaceMechaniX
                • Sep 2007
                • 2831
                Correct. You can go to 3V/cell when you get familar with charging and running, but 3.3V/cell is safe. Still I don't recommend running till you have a charger.
                Tyler Garrard
                • Visual Perfection
                  • May 2010
                  • 312
                  Thanks for your help!
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    With all due respect, I'm afraid I'm going to have to disagree with you slightly RaceMechaniX.
                    Storage voltage is best at around 3.8 V/cell. And leaving them lying around for a few weeks fully charged does more damage to them than being under charged. So I would run them for a couple of minutes & check the resting voltage. If it is still above 3.8v/cell run them a bit more & check the resting voltage again.
                    Don't get carried away & over do it though.
                    The batteries can be stored for a long time at 3.8V/cell
                    All the best.
                    Paul.
                    • Visual Perfection
                      • May 2010
                      • 312
                      Thanks for your response!
                      • RaceMechaniX
                        • Sep 2007
                        • 2831
                        I agree its bad leaving them fully charged and ideally he would run them down to a safe level.
                        Instead of running them in a boat though I would do it with a discharge bulb or similar. Too easy to go overboard when running a boat.
                        Tyler Garrard
