Did I fry my LiPos?
  • CinciKid
    • May 2010
    • 7
    Did I fry my LiPos?
    I can't seem to charge my 2 lipo 3200mah batteries anymore, and I only used them twice! I use the Dynamite Passport LiPo/Life AC/DC Battery Charger, and when I plug up one of the battery and press the charge button, it flashes red and repeatedly beeps at me, in the manual it says it will do that when the balance plug isn't attached, but it is. The other battery just doesn't seem to register at all on the charger, I plug it up and push the button and it adjusts the cell size, like the battery isn't plugged in, and nothing happens, and the charger is only a few weeks old! Anybody got any ideas?
  • Doby
    KANADA RULES!
    • 7280
    Broken connectors on your balancing taps? On your power leads?
    Is the balancer plug orientated the correct way?
    Just some thoughts.
    Grand River Marine Modellers
      When you last ran the packs, what were they in? Did you run them down until the boat stopped? Do you have a voltage meter to measure the pack voltage? It is hard to tell if the problem is the cheap charger or the cells......
      • CinciKid
        • May 2010
        • 7
        No broke lead that I can see on the outside, yes the balancer plug is oriented correctly. I last ran them in my BJ 26 and ran them until the boat stopped in the water, but it was close enough to reach from shore.
        • ED66677
          • 1300
          If you ran until the boat stopped you probably damaged them!
          get a voltmeter, and measure each cell on the balancing taps and on the power leads as well, get back with numbers!
          Emmanuel
          • CinciKid
            • May 2010
            • 7
            I confirmed my fears today, I either fryed them or they're soo drained they're done. I picked up some new batteries and they charged no problem, I switched my esc to 'Idle' instead of 'slow down' when the batteries get low, hopefully I don't burn out these new ones.
            • Eric Bourlet
              • Jan 2010
              • 104
              Never take the LiPos below 3volts per cell. Make sure you use a digital volt meter and check the cell voltages on the pack. If you don't have a DVM then don't run lipos. If you don't have a low voltage cutoff on your ESC you need to get one and make sure you set it to 3 volts per cell.
              Eric Bourlet
              Team Airtronics
              Team M&D Designs
              • Diesel6401
                Memento Vivere
                • 4204
                I keep these in my pocket at all times when running. I also try and carefully watch run times.
                http://www.hobbycity.com/hobbyking/s...itor_2-8S_Lipo (i didn't install in my boat i just plug my lipos in to checks exact voltage after each run, its very accurate when compared to my chargers and even my fluke meter.)
                http://www.harborfreight.com/non-con...ter-93983.html (this has a timer/stopwatch to moniter run times.)
                - Diesel's Youtube
                - Diesel's Fleet
