bigdg, what turnigy packs were they? c-rating? did you ballance them ? also how many cycles? after it died did you find out the cause for thr failure? i.e. dis assy pack to find?? check voltage per cell? i have yet to have a bad turbigy, but their all high c rated and high mah..
Turnigy Cells Crush G3's
have you opened the packs up for a look. if you do do so carfully.
i run turnigy cells and think dollar for dollar cant be beat,i cant see a battry worth 5x more is going to be 5x better.
i have seen one of the turnigy packs work for half a run and stop,after a carful look my mate found one cell wasnt soldered properly across the tag,after a quick solder it works fineComment
I had a set of the turnigy 3s packs and both packs just died one died mid run in a boat the remaining of the set was used to power a traxxas stampede this one also died in the middle of a run in both cases the batteries were not even warm . I have heard of this problem from others also after doing the research after the first one died . I am using zippys now with no problems at all .Just thought I'd throw that out there I mean what are the chances of 2 packs failing in the same way
JohnChange is the one ConstantComment
I have not, but I have actually posted about the problem on an earlier thread which I'm not sure on exactly where but one of the members tth was so kind as to take a look at it for me not sure what exactly he found ,maybe he can chime in but he was feeling unsafe with the opened pack so I told him to trash it and I would not know where to begin repairing one. I don't really see a battery worth 5x more is going to be 5x better either so I have been ordering zippys 3s 40c 5000mah for 45 usd and I have just recently ordered 4 2s packs 30c 4500mah for 25 usd definitly worth a shot if they blow and I replace them I still didn't spend as much as I would have on maxx amp packs.Comment
bigdg, what turnigy packs were they? c-rating? did you ballance them ? also how many cycles? after it died did you find out the cause for thr failure? i.e. dis assy pack to find?? check voltage per cell? i have yet to have a bad turbigy, but their all high c rated and high mah..Comment
ive experienced the higher the c- rating ( wich doesnt cost much more and even cheaper in the turigy the better quality. he should have located the bad cell and disposed of it, then you have a good pack but just lower v. for another toythis is what i do, infact i have 6-8 , 25 c packs i puffed ( my fault) testing motors in my plane that ill tear apart and re-build into 4's packs instead of 3's.. its easy! "you can do it"!
Once I opened the pack there was a fluid all over the bottom of all 3 cellsl. It was not puffed but the bottom seam on the middle cell was open. Really smelly!!! There was a circuit board that the tabs were all soldered to. I have repaired many of my cheap packs that I bought when I first started the hobby.True RC and Elite mostly. They were all easy repairs 4s to 3s or 3s to 2s. After all the discussion on these Flightmax and Turnigy cells I may have to try some.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
Exactly what I did but the circuit board on the top that all the tabs are soldered to prevented me from doing the conversion. If the middle cell is not there it is an incomplete series. It would not been bad if it was the 1st or 3rd cell but it was the 2nd right in the middle. With the 2nd pack being open at the seam on the bottom I was uncertian of its possibilities.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
Exactly what I did but the circuit board on the top that all the tabs are soldered to prevented me from doing the conversion. If the middle cell is not there it is an incomplete series. It would not been bad if it was the 1st or 3rd cell but it was the 2nd right in the middle. With the 2nd pack being open at the seam on the bottom I was uncertian of its possibilities.Comment
Balance leads are a piece of cake. When I saw that circuit boardthen when I noticed the fluid coming out of the middle cell with the split in it
all I could think of was..............
I peeled the wrapping seen the board and pretty much gave up there, that was my problem not exactly simple circiutryComment
man I must be lucky, I have only killed ONE Polyquest lipo pack, that was due to a magnets coming apart in the motor. Now NiMh cells............
I don't think I will try Turnigy, the esc,servos and batteries that club members bought and tried, are all fried.
I have good luck with Hyperion G3 cells, Polyquests and Poly Rc, and Neu. and for the money Rhinos performed very good for me as well.Comment
Interesting what everyone has to say about different batteries. I purchased 3 Turnigy packs back in mid September. I got a 3S 20-30C and two 2S 30-40C packs. I might have 10 cycles on the 3S and 15 on both 2S. So far Ive had great success and am very impressed with them. Not that they have been mentioned, and honestly, Im not even sure how they rate as they are the only packs the LHS had when I purchased my first FE boat, but I have a pair of 2S 5000mah Reedy hard case packs. $100 each and I had one puff on the 3rd or 4th cycle. The LHS nor Reedy would do anything about it. I purchased another Reedy and so far have had no more issues. That was back in June or July. But to compare those against the Turnigys, In a 32" cat, BJ26 ESC and motor, Pair of Reedy 2S 5000 pushed it 39 and change. Same ratings in Turnigy got another almost 2mph. That was impressive enough for me. Im working on gathering parts for my next build and I plan on using Turningy 4 or 5S packs.
Just wanted to share my experiences with the Lipos Ive run....
ScottComment
Ok so I'll jump in here.
I have an amazing ability to destroy stuff. ESC's and packs are my speciality.
I have rooted a few Zippy's and a couple of Rhinos too.
I have managed to puff Polyquest and Flightpower packs too.
Now here is where I sit.
I have bought a few new Turnigy packs and did so because they are the best bang for the buck there is.
I have 2 that I have done some very unkind things with and they still love me.
I would never be bold enough to say that they are as good or better than the high end packs like the G3.
They are hardy and suit what I do. They are my choice of pack.
When the last of my zippies and polys die I will replace them with Turnigy. Not because they are the best but because they are good value for money and I have not poked one yet. That will make one die now for sure
Go with the G3 or better if you are after all out speed, go with the Turnigy if you are after bang for buck. I have done both and know which side my bread is buttered.See it....find the photos.....sketch it it....build it........with woodComment
