delta force vortex hydro
  • 2ltrvtec
    • Jul 2009
    • 61
    im planning on swapping my sv27 gear into this hull. im running a single 4s1p. my question is about motor placement. i read somewere on here about putting the motor further towards the transom. if i did that and put the pack in the center of the boat in front of the motor with receiver and pack on one side and servo and esc on the other would the COG be alright? how is everyone else with this hull setting up theirs? pics maybe?
  • Rumdog
    • 6453
    I ran 2x2s lipos. I ran them in the sponsons. The motor was about at the place where the bubble in the hatch is it's largest. For me, the hull handled best with the cg at 1-1.25 inches behind the rear sponsons. place everything in the hull where you think youll want it and check the cg.
    • domwilson
      Moderator
      • 4408
      Are you going to transfer the hardware as well?
      Government Moto:
      • SLAUGHTER_AUS
        • Sep 2008
        • 52
        votex
        Well to give you an idea here is how mine is set up, i have shifted one pack into the left hand sponson to settle it down in a stright line, it runs a blackjack motor and sv27 speedy.
        will try till smoke?
        www.slaughtermotorsport.com
        • 2ltrvtec
          • Jul 2009
          • 61
          yes that was my plan. is that an issue?
          • SLAUGHTER_AUS
            • Sep 2008
            • 52
            You will need a new strut and may have to shorten the rudder thats all. the original sv strut wont work on type of boat.
            • 2ltrvtec
              • Jul 2009
              • 61
              what kind of strut do i need and what do you mean by shorten the rudder? bring it closer to the transom or the actual length of the rudder itself
              • j.m.
                • Jul 2008
                • 838
                try this strut>
                http://www.offshoreelectrics.com/pro...d=ros-21-strut
                and you'll need a hydro turn fin>
                http://www.offshoreelectrics.com/pro...od=dh-aqub9515
                • domwilson
                  Moderator
                  • 4408
                  It may be. you may not get the kind of adjustments that are required of a hydro. One being strut height. Hydros are a bit more difficult to get running properly as they operate on the water a little differently from monos.
                  Government Moto:
                  • 2ltrvtec
                    • Jul 2009
                    • 61
                    Originally posted by j.m.
                    thank you sir. now can i pull the stuffing tube out of the sv hull and put it in the vortex? and then run the same drive cable.
                    • 2ltrvtec
                      • Jul 2009
                      • 61
                      should i run the motor behind the pack near the transom with pack running bow to transom or the motor farther up with the pack port to starboard in front the motor about an inch back from the sponsons?
                      • j.m.
                        • Jul 2008
                        • 838
                        Put the pack sideways as far forward as possible, then the motor as far forward as it needs to be to get the cg at 1" behind the sponsons with all your other gear in the boat. (servo, esc, Rx in appropriate places)
                        • Bill-SOCAL
                          • Nov 2007
                          • 1404
                          No, you cannot.
                          Don't get me started
                          • j.m.
                            • Jul 2008
                            • 838
                            You'll def need a new cable and tube. [much longer]
                            • 2ltrvtec
                              • Jul 2009
                              • 61
                              can i use a 3/16th prop shaft so i can use my sv drive dog? and what prop should i run? somthing much smaller than my cf 48?
