Mean Machine Catamaran (Sport)
  • DISAR
    • Aug 2007
    • 1072
    #76
    As you understand unless you use a motor that it has been run and tested by someone and then by somebody else you will not get many answers to your questions.
    Testing is the best thing you can do taking the risks ofcourse. My proposals are based on estimations and calculations and where you can start. Start with the smaller propeller and when everything is cool start going to bigger ones.
    http://www.rcfastboats.com/
    • sewerpit
      • 117
      #77
      mr fluid
      great info, maybe you can help me a bit with props, there are so many people using diff set ups with good results and it can get confusing . i will be running my mm with an 8xl ,hydra 120 esc on 4s2p what props should i be looking at for sport and then for speed thanks for your input MR.watts your input would be great too thanks
      • calcagno45
        • Mar 2008
        • 1006
        #78
        Mel: I would stick with the Octura X and M props. Those CNC props are pretty unchartered territories compared to the tried and true ability of the Octuras.
        As far as the voltage cutoff on the Hydra, most people will set them anywhere from 3.0-3.3v per cell. Never go below that 3.0v per cell.
        Sewerpit: I would try a X440 or X440/3 to start. Make sure everything is good and then start propping up. Another nice prop on the MM is the Y537/3. good speed and drops the amps.
        • bustitup
          • Aug 2008
          • 3071
          #79
          Originally posted by Mel279
          Hey thanks, what cutoff voltage should I set on hydra 240 if Im using 6s?with 12xl motor, can I reach 60mph on that?
          Well on rc cars this how you figure it
          There are 3,7 volts per cell so. A 6s lipo has 22.2 volts
          So to figure cut off take the number of cells x 3.2 so in you case 3.2 x 6. = 19.2 would be the safe cut off
          • Mel279
            • Dec 2008
            • 857
            #80
            Hey bustitup, thanks for the info regarding the cut off
              • 9488
              #81
              what speeds should a MM get using 4s on a 8XL ?
              thanks, I love my MM !
              • obrien
                • Nov 2007
                • 1264
                #82
                my guess would be mid to upper 40mph range
                • toysRme
                  • Jul 2009
                  • 75
                  #83
                  Originally posted by Nautiboyz
                  Guys, What rudder offset are you running with the speedmaster hardware???
                  Thanks!
                  Just got my hull from OSE and want to the same info???
                  intended setup
                  seaking 180A
                  Feiago 9xl
                  zippy 4s 5000 30c
                  x440
                  speedmaster hardware mono strut and 5.5 inch rudder
                  any input would be appreciated
                  STUFF NITRO GO LIPO FASTELECTRICS.COM
                  OFF-SHORE-ELECTRICS.COM
                  INVENTOR OF LITHIUM CELLS:bowdow
                  • rawsonreyes
                    • Aug 2007
                    • 102
                    #84
                    new mm setup
                    hi guys the whole thread got some great setups but has anyone try the 580motors from steven. i have got an 90amps quickworldwide.com esc starts at 6s can this setup be eff, props x440/442/447 i do my own prop mods/ s/b/det also cupping. speedmaster strut/5"rudder.could this range give 50-60mph.rreyes.
                    • Scott T
                      • Oct 2007
                      • 590
                      #85
                      intended setup
                      seaking 180A
                      Feiago 9xl
                      zippy 4s 5000 30c
                      x440
                      My rudder is just inside the edge of the right sponson. Seems to work very well. Pics in this thread - http://forums.offshoreelectrics.com/...ghlight=aussie
                      You should be able to bump up to an X442 and maybe even an M445 with that set up, but start with the X440 and see how she goes!
                      Scott Tapsall
                      Pine Rivers Model Powerboat Club - Facebook Page
                      My Gallery
                        • 9488
                        #86
                        I think I saw a MM with a 580 and it was nuts!
                        • sailr
                          • Nov 2007
                          • 6927
                          #87
                          Doesn't that depend on the esc? Some have cutoff set at the volts per cell, eg. 3.2V and some are set as a multiple of 3.2V X #of cells.
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • ozzie-crawl
                            • Sep 2008
                            • 2865
                            #88
                            was asked for acouple pics of my MM setup, thought i mite as well put them here
                            • bustitup
                              • Aug 2008
                              • 3071
                              #89
                              I was referring to how to determine HOW to choose the voltage cut off you would choose if the esc gave you a bunch of options
                              for instance the castle link gives you a list of voltages to choose from....the formula i presented shows you how to choose the proper one
                              • eboat
                                • Aug 2007
                                • 693
                                #90
                                Looks good but you should pull the shrink off the esc and water proof it (I have the same one and have seen one that got wet at a club race and melted)
