Delta 29" copy build -help needed!
  • FastVee
    • Aug 2008
    • 649
    #151
    Yeah, thanks ,now I know how to calculate the pitch from"
    Now I need to learn how to compare the larger dia props with less pitch to smaller ones with more pitch
    And I thought that I know everything about rc...(b4 I started rc boating)
    www.youtube.com/rangerpate
    • domwilson
      Moderator
      • 4408
      #152
      Good explanation... http://www.modelpowerboat.com/forum/...propellers.htm
      Government Moto:
      • domwilson
        Moderator
        • 4408
        #153
        How to on prop mods... http://www.rcboat.com/prop.htm
        Government Moto:
        • FastVee
          • Aug 2008
          • 649
          #154
          Thanks a lot Dom!
          You posted that last one on the "differences between props" -thread ,
          thanks for the links you provided on that thread too!
          • domwilson
            Moderator
            • 4408
            #155
            I like being redundant sometimes. It makes it easier for people to find information.
            Ok, It's a good excuse for me getting older and forgetful.
            Government Moto:
            • FastVee
              • Aug 2008
              • 649
              #156
              Boy did I have a good time yesterday.
              Drove it for 2 mins(still sv parts in use), took tapes off and wiped the hull usind the towel I use to dry seats on my 1:1 boat. Checked temps and taped it close.
              It went nice until it hit a wave and dived in .When it surfaced (upside down) I noticed BUBBLES! -taking water and fast, took me 5 sec to get to it and by then it was full with water... -and smoking... pulled it out from water and noticed that the tape was off at the left rear corner! -ripped the hatch off and yanked the batteries out.
              Luckily only the BB 630MG WATERPROOF servo fried.
              The reason that this happened... THAT DAM TOWEL HAD SOME GREASE ON IT !
              After I got it back to shore, in to the shower it went -motor esc and all.(I drive this on sea ,remember). I dunked the electrics quickly in denat.alchohol and let dry.
              Replaced the shrinkwraps on batts too.
              This morning everything(except the servo) worked fine again.
              So keep a clean rag with you when boating,
              and make sure that the surface is clean b4 applying tape
              -Pate
              • ED66677
                • 1300
                #157
                That's BAD... but finally not too bad! Could have been worst!
                I always have a paper roll we me at the pond, never use a sheet twice!
                Emmanuel
                • FastVee
                  • Aug 2008
                  • 649
                  #158
                  Just received my new Turningy 5000mAh 2S1P 30/40C lipos.
                  WOW! 8AWG wires and 5.5mm bullets for this cheap!
                  I just hope that these are great performers too! (like the 20/30c ones I have used).
                  Testing the C rating.....
                  (and, yes thats me)
                  • ED66677
                    • 1300
                    #159
                    that must be a monster! how much $?
                    Emmanuel
                    • FastVee
                      • Aug 2008
                      • 649
                      #160
                      (you must be talking about the lipos )
                      31.41$ https://www.hobbycity.com/hobbycity/...idProduct=9514
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        #161
                        thats great they have the bullets already on them know as mine were a pita getting 8g wire in 5.5mm bullets, i have 4s 5000 turnigys
                        • FastVee
                          • Aug 2008
                          • 649
                          #162
                          Took er out for a spin and the motor is ....(well it cant be good , meseaured the temps when I got it back to shore and it was 86c -after 5minutes it was turned off!)
                          -dam that green stuff is nasty ...blocks the cooling so well...
                          few pics of last session.
                          More pics here http://kuvablogi.com/blog/4540/44/
                          • domwilson
                            Moderator
                            • 4408
                            #163
                            Keep at it. I think you'll eventually get it all out of the lake.
                            Government Moto:
                            • XanderAnder
                              • Aug 2009
                              • 1
                              #164
                              I'm starting to build same boat, but it can be so hard to get good motor,hardware...
                              Let see what happens when I start it.
                              • FastVee
                                • Aug 2008
                                • 649
                                #165
                                Xander, the easiest thing to do would be to get the sv electronics and the speedmaster hardware.
                                If you have some diy spirit, get the himodel 200a esc and waterproof/cool it.
                                then add 8xl and it will fly.
                                Pate
