Good catch steve.....that cowl would not work on MY mm ........I run a castle Nue 2200kv with kb45 water jacket
New Mean Machine cowl
Steven,
Yes, it could be an issue for existing boats. New builds would be fine. My motor sits pretty flat because I mounted it forward, so it's under the flat part of the regular hatch anyway.Comment
I will be vac pulling some of these soon for my hulls. Easy to do but I want to use pretty thick polystyrene for it. Glass is nice but you can change the mold of the vac forming very easily...glue it on and it is added...like intakes, etc.
I would prefer glass but I can pop these off in minutes once I get set up...flat board and the rest is just changing the canopy block. I like twins cockpits as well.Comment
Jeff,
I think there is a huge untapped market out there for aftermarket hatches. Vac-u-Boat are onto it by offering 3 different cowls for their Pickle - very smart I think. Will be interested to see what you come up with.Comment
Trying to finish a vac former I have plans for. Simple yet easy.
Well the best thing about Poly is cost. I would like to see three or four on some for the same model boats so they differ.
I would also like to see everyone running a sub hatch and have some kind of mechanical holder on tops so fewer are lost in crashes.
I will see what I can do. I also have a bunch of clay that hardens very hard. The one I want is the old EV hull canopy. I have a couple and I was going to fine something cooler. MM is also one I hate as well.Comment
You did an excellent makeover, I always thought MM cat had an unattractive cowl, but with a lil' creativity you've given it a second life.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
Its a good idea to make it think Jeff, the hatch is huge and could collapse in a crash if it was made out of thinner stuff.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
