Hydra 120 settings
  • sci-flyer
    • May 2007
    • 35
    Hydra 120 settings
    Got a SV27 with an 8XL and 4S-2P.
    What settings should I use?
    I am thinking a X442 prop, is this a good starting place?
    Thanks.
    An x440 or x442 should be a good place to begin. Start with the Hydra120 timing on "low". What cells are you running? That will help determine how far you can go in prop size and timing.
    • sci-flyer
      • May 2007
      • 35
      I have PolyRC 30C packs, only 3000mAh each so runtime will be short.
      With 4S-2P, thats 6000 right? How do I figure actual runtime?
      I will try the low setting first.
      Thanks Fluid.
