32" Mono Build
  • sailr
    • Nov 2007
    • 6927
    #31
    The hulls I have gotten from them have been good quality. No problems.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • lincpimp
      • Jul 2007
      • 252
      #32
      Thanks for that info, makes me feel better.
      "These rocky mountains aren't very rocky!" "Yeah, that John Denver is full of S**t!"
      • bustitup
        • Aug 2008
        • 3071
        #33
        Linc if you decide to ditch the hull I would like to buy the cowl
        Originally posted by lincpimp
        Well, I just bought this boat from Nate, enjoy the money dude. I hope the hardware on this boat is as nice as the pics look...
        Sailr : are these hull decent quality?? I only ask as you said you have 6 of them... As long as it will handle 45mph and slight chop I am fine, the pond I run it is pretty calm.
        Not giving you a hard time Nate, you got you money back from the seller, but you had to spend the time to get it, plus you still have to find another hull. So I consider the money I paid you for your trouble and hopefully you can score up a boat in the US from one of the better vendors. Honestly, 100 bucks for the hull shipped was worth it, I could toss the hull and keep the hardware and make out. Shipping will be close on 20 bucks anyways.
        I will fix the hull, as I know a guy who owns a auto body shop (me), and he is good with glass and paint and he is good with the ladies too (not much use for the boat repair, but good for him!!) Plus he likes projects too, and has a hankering to custom paint a hull or 2...
        Enough of talking about myself in the 3rd person. Tine to break out the grinder and some resin... Or maybe just kitty hair and let it fly...
        • Chuck E Cheese
          • May 2008
          • 1684
          #34
          i also have this hull with good luck, mine came packed well with no damage.
          LINCPIMP - you will be verry disapointed with the hardware. the trim/rudder/turn fin are good but the strut is junk. it uses a stub shaft with a squar flex that slides into it, werry hard to maintain and weak. i used a speedmaster stinger.
          i have also ordered several blank 26" copies and never had a poblem with damage...
          here is what i did with it. kind of a different style but i wanted to experiment with a removable shelf for the rec/servo.
          see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
          • Chuck E Cheese
            • May 2008
            • 1684
            #35
            first i laid CF on the floor and trandsome, then made a CF shelf and mounts for the batteries/rec/servo and bec
            • Chuck E Cheese
              • May 2008
              • 1684
              #36
              i set it up with cog at 9.75-10.75" which has worked good in the past on this hull. i am using a 1515 1y and cc240 on 9800mah 4s 25c starting with detounged x442. this set-up should yeald around 48 mph and reliable.
              i have played with this hull before. 8xl x445 4s = 48mph, 12xl x445 6s = 48-50mph
              • nate
                • 1652
                #37
                No it wont have a junk stub shaft, I included a brand new Octura .187 flex for him...
                Should be a good boat with minor work here..
                LMT
                LehnerMotorenTechnik.com
                • sailr
                  • Nov 2007
                  • 6927
                  #38
                  The Chinese and the Europeans love those stub shafts with square end cable for some reason. Chuck's right, they are junk! I'm haggling with one of the manufacturers now tht if they won't change out this setup to a 3/16 shaft with .150 flex, I won't buy their products.
                  Mini Cat Racing USA
                  • nate
                    • 1652
                    #39
                    Yea I know there junk thats why I threw in that .187 flex..much better..
                    LMT
                    • Punisher 67
                      Ignore list member #67
                      • May 2008
                      • 1480
                      #40
                      Just out of curiosity can someone take a photo of one of these drives , I purposely use a .250 square end on all of my extreeme high powered setups at the strut with excellent results , is it the square drive or is it the fact that its just to small .
                      Just curious guys please don't read anything negative into this................
                      Necessity is the mother of invention.............
                      Youtube Video's http://www.youtube.com/user/Titanis2000
                      • sailr
                        • Nov 2007
                        • 6927
                        #41
                        First, you have to REMOVE the strut to pull the shaft to grease it! That sucks! After finally finding the correct strut setting, you have to disturb it! If it's square on the motor end, unless a really good coupler that's really deep for the square shaft to fit in, they tend to round off. Big 1/4" stuff might be OK but smaller it's not in my opinion.
                        Sorry, don't have a pic.
                        Mini Cat Racing USA
                        • Punisher 67
                          • May 2008
                          • 1480
                          #42
                          Yes that does sound like a weak setup . the way I have mine is like the gas guys , very easy to maintain and bullet proof strength wise
                          Please don't take my questioning as an attack
                          • sailr
                            • Nov 2007
                            • 6927
                            #43
                            Peter, how do you grease the shaft without removing the strut? Or is you shaft just square on the motor end?
                            Mini Cat Racing USA
                            • Chuck E Cheese
                              • May 2008
                              • 1684
                              #44
                              i use the square like your in my gas with good results but these set-up's are on the strut end... sailr nailed it with the adjustment comment..
                              • Punisher 67
                                • May 2008
                                • 1480
                                #45
                                I can remove my strut in 45 seconds ( only 4 bolts ) and back again with absolute alignment in the same amount of time . I have a small hole in the strut that I spray grease through without even removing it pushing all the water out , the square end is only on the strut , the motor end is a grub screw coupler . I am real curious how these boats come sounds like a nightmare to maintain
