Well I'm home from work since the wife is not feeling well and the little monsters are still in school so I thought I would share a few lessons learned and a few upgrades I made to my Titan 33.
Based on what I have read on this board I knew the .150 flex I was using with my 1515 1y was the weak link in my drive line. I did not install the .187 flex when I built the boat because I did not originally plan on Neu power and Lipo packs at the time of the build. I resisted upgrading the flex since I didn’t like the ideal of ripping out the stuffing tube and replacing it with a larger one. Once again I learned that if you know something needs to be fixed or upgraded and you don't do it, the justification will be done for you. My flex snapped and what you see is in the enclosed picture. The flex wrapped around my ESC cable and also totally shredded the stuffing tube that was exposed outside of the wooden stuffing tube support.
Well what to do now.... The logical choice was to install a .187 flex. But I wanted to get back on the water as soon as possible and Steve didn’t have everything I needed in stock. The only other option was a piano wire drive. I was never keen on the idea of wire drive. There are not many build threads that have them. Also, I have a Fine Design strut. How am I going to make that work with the small stuffing tube required for the wire drive? Well, after some late night web surfing and a few emails to Jeff Wohlt I decide to take the plunge. I ordered a .078 wire drive system and coupler from Jeff and some brass tubing (5/32 and 3/16) from OSE. I also decided to go without Teflon which is another first for me. I ripped out the old stuffing tube and supports. I cut a short piece of the 3/16 tubing and slid it about 1/8" inside the nose of the strut. The other end ended up being about 1/2" inside the transom. Then I slide the 5/32 main stuffing tub inside the 3/16 tube making sure the tube ends were even inside the strut. Then I epoxied everything into place. I trimmed the 5/32 to the appropriate length at the coupler and slid another short piece of 3/16 at that end for some additional strength and support. I installed a new plywood stuffing tube support on the coupler end and shrink wrapped the 3/16 tube at the strut and I'm back in business. I'm just waiting for a drive dog to arrive from OSE. Those of you contemplating wire drive, remember it's only good in installations where there is only a little bend in the drive line.
Now another thing I noticed when I was assessing the damage on my boat was that if I put any torsional force on my motor (grab it and twist), the hull flexed and the motor moved a little. This may have also contributed to the demise of my flex cable. So I fabricated some marine plywood rails. Soaked them in penetrating epoxy. Painted them up and epoxied them into the boat. Now the flex on the hull is much reduced.
Lastly I added a little lead to the boat to keep here a little more stable at speed in race water. I have about 15 ounces in there. CG is about 31% without batteries.
Thanks to Jeff Wohlt for his guidance on the wire drive and Egneg who’s massaged X640 I will get to try out this weekend. Gurus, feel free to correct me if anything looks amiss or I passed on any bum info.
