VIPER by H&M Conversion Brushed to Brushless
  • Camman
    • Jan 2008
    • 77
    Finally got around to work on my Viper
    Old school Nmh & 700 Cordite just does not cut it with the BL/Lipo nowadays
    Saw all these UL-1's on the scene at our club "HOTMBC" Thought I had a good platform to start my
    UL-1 killer
    After some looking real close when stripping her down I noticed rudder might had been dragging. With straight edge to bottom of hull runs right into rudder where it shouldn't
    Gona have to scooched things up some on transom & reglass
    Everything scooched up & reglassed
    Thanks for looking
  • Camman
    • Jan 2008
    • 77
    Viper
    Every thing out
    Test fit AMMO 36-56-2030kv with OSE cooling jacket & 2 packs 5000mah 25C Hyperion Lipos
    Industrial Velco with straps
    Velcro under 60 amp Aquacraft ESC
    • Camman
      • Jan 2008
      • 77
      Viper
      Make a mount for my steering servo, epoxy in with slow cure epoxy
      • tth
        • Apr 2008
        • 1510
        Good decision to make the jump to brushless/lipo power. You will definately be surprised when you pull the trigger. I am in the process of building up the one in my avitar right now. Set up correctly these boats are very comfortable in the mid 50's. Don't forget to get some video.
        • Camman
          • Jan 2008
          • 77
          re: pulling the trigger
          HOLY SMOKES
          Tracy
          You were not kidding about the difference when pulling the trigger
          I did not run to big a prop so went with a K42 & man !!!
          when you say go it GOES
          I am so glad things are going as good as they are. I was reluctant at first to play with the FE stuff but now I am soooo glad I did.
          I can not wait to finish sharpening & ballancing some other props for this weekend
          I must have tabled it very well because first run I could literally pin the throttle & just steer it around the course
          Zero signs of anything bad
          Temps after first race esc 103, batts 99 & motor 99
          I think I can prop up don't u'al think ?
          Mike
          • RayR
            @SiestaKey.calm
            • Jun 2007
            • 1518
            Get's a little loose at that speed doesn't it! Have fun, sounds like you already are.
            All the best,
            Ray
            • Camman
              • Jan 2008
              • 77
              All the best,
              Ray
              Actually it was not all that loose at all
              I was really surprised that it ran very very smooth & tight no dancing at all
              I will try to get someone to shoot vid this weekend
              I am sooo hooked on FE
              especially these smaller boats
              pretty cheap for the speed you get
              • Meniscus
                Refuse the box exists!
                • Jul 2008
                • 3225
                Are you running a turn fin? I don't see one in the pictures.
                I find that mine doesn't run loose either, but I have to be very, very careful with the COG. Otherwise a blow-over is certainly in order.
