Viper Turbine.....Miss Budwiser Build
  • tth
    • Apr 2008
    • 1510
    I would like to share a few pics of my newest member to the fleet. Many thanks to Diegoboy for giving me the info on where to find the hull.
    A couple pisc have the Viper Turbine cowl and the others are the with the Viper II cowl. I hope everyone enjoys the Pictures!!!
    I am thinking of the following setups:
    Neu 1512/2D..................... Lehner 1940/6
    4s1p 5000mah ..................4s1p 5000mah
    Etti 150/Hydra 240 ............Etti 150/Hydra 240
    Speed Master HW ..............Speed Master HW
    .150 Flex ............................150 Flex
  • line6
    • Aug 2008
    • 478
    Looks nice. I really like these vipers i wish it would stop raining here so a can paint mine
    • tth
      • Apr 2008
      • 1510
      I have a Viper II that is almost identical with the Miss Budwiser theme. This Viper Turbine is #2 on my favorite hull list. These boats are very fast and if setup correctly, handle like they are on rails.
      • Ub Hauled
        • Aug 2007
        • 3031
        Do you have both hatches? That's cool... run each a different day depending on the mood...
        • tth
          • Apr 2008
          • 1510
          I have 2 Viper hulls, one is the Turbine and the other is the Viper II.
          • line6
            • Aug 2008
            • 478
            Hay tth whats a good starting point for the strut height and angle. and also the c.o.g getting ready to put mine together. It will be powered by I UL-1 motor on 4s. Thanks
            • tth
              • Apr 2008
              • 1510
              On my Viper II, the strut is set at 12mm bottom of transom to top of flexshaft with a neutral angle. Center of Gravity is 34mm behind sponsons.
              • Meniscus
                Refuse the box exists!
                • Jul 2008
                • 3225
                Have you tried that X642 prop on the new hull yet? What kind of speeds are you seeing?
                • tth
                  • Apr 2008
                  • 1510
                  I don't have the new hull Turbine hull set up yet. The x642 D/T yielded 56 mph on the Viper 2 hull with an 8xl on 4s1p 4100 30c Neu Lipo's. On your Viper thats Solinger HW right? Ask Danny if he used the mono or hydro HW. My Solinger Hydro HW looks like it won't have any room for adjustment. I may even do Speedmaster setup, just don't know yet.
                  • Meniscus
                    • Jul 2008
                    • 3225
                    Yes, mine has the Solinger hardware. Danny had Hydro HW, but I bought from him without because I couldn't afford it at the time and he needed for another project. I ended up finding some Mono HW that I traded some stuff for. Then I flipped over the arm for the rudder. I'll confirm that again to be sure. I'd run the Hydro HW if I were you....and mount to the left
                    I wouldn't worry about too much adjustment. Mine has wire drive and there is very, very little adjustment available. I've been going through props and adjusting accordingly. I just have to stop hitting fish!
                    What hardware are you using on the Viper 2?
                    • tth
                      • Apr 2008
                      • 1510
                      Viper 2 has the FDM hardware. This is the first Viper "Miss Budwiser" I bought from Danny.
