Hi Jimmy, if you have allready taped the holes for the hardware in the transom then you can just glue the back 1 inch of the cowl straight on as that is what I did with mine and it does make it heaps better to tape the lid down. I have done the same for the Sport 45.
A small tip if you like before you glue the servo down, I had 2 layers of carbon put down over the entire rear bay to stiffen it up. Try and glue the servo onto as much of the plywood insert as possibile as its the strongest point, maybe drill some small holes around the area and fill with epoxy to join the top and bottom skin together.
Your setup is looking the same as mine and it does work very well.
It should be good racing against it during the Brisbane Thunder event.
Shane.
Shane.
