Prop work
  • kookie_guy
    • Jun 2008
    • 897
    Prop work
    I'll post this here because this area is generally most populated with seasoned guys. Anyhoo, I got my X642 nicely balanced and super sharp. Now the controversial million dollar question......
    To polish, or not to polish? Searching google for several hours, there tends to be a difference of opinion on the topic. I'm asking the guys with experience, what works best?
    1) No polish?
    2) Polish only front (nut side)?
    3) Polish only back (drive dog side)?
    4) Polish both sides?
    From what I found, #3 is never done, just left a nice brushed finish. So the big question is really the front (nut side) of the prop.
    cheers.
  • jingalls007
    • 1015
    polish ONLY the front. you will notice quicker acceleration out of the turn if you don't polish the back end.
    • Gerwin Brommer
      • Dec 2008
      • 918
      you will NOT notice any difference in speed, front polished or not !
      • jingalls007
        • 1015
        Perhaps someone would be willing to test this theory with there nifty eagle tree data software. Duc perhaps??
        • Gerwin Brommer
          • Dec 2008
          • 918
          You can't test it.
          Windspeed, waves, batterytemp, wind-direction,all that should be 100% the same while testing before/after polishing.
          And what would be the outcome of the test ? A 1/4 of a mile/h difference ???
          that doesn't prove anything.
          • jingalls007
            • 1015
            Originally posted by Gerwin Brommer
            You can't test it.
            If you had two identical prop's one polished one not then you could run a 3 minute heat with one, take the boat out, run a 3 minute heat with the other. That would keep the testing conditions relatively the same. It would be an interesting test either way.
            • Raydee
              • May 2007
              • 1603
              I have done it each way and I can't tell the difference in performance. I polish mine just so they look pretty sitting at the bottom of the pond
              Team Liquid Dash
              • kookie_guy
                • Jun 2008
                • 897
                thanks for all the input guys. I'll probably polish it up just for looks as well then.
                Raydee, you polish the front (nut side), what about the back (drive dog side)? Do you leave it raw or do you sand it?
                • jingalls007
                  • 1015
                  been there, it sucks..
                  • teach
                    • Jun 2008
                    • 509
                    Thanks Raydee, I should make that my signature!
                    • bwells
                      • Jan 2009
                      • 842
                      wait a minute, I'm confused, I thought the front was the drivedog side and back the nut side. I sharpened and smoothed only the drivedog side. Is this where I goofed? I read to leave the back(nutside) alone as this creates splash and that is a good thing. opps
                      • jingalls007
                        • 1015
                        that's how I understood as well, could be an oversight....either on his end our ours
                        • egneg
                          • 4670
                          The face is towards the back.
                          IMPBA 20481S D-12
                          • kookie_guy
                            • Jun 2008
                            • 897
                            the sites and DIY's I read, the front to back was something else. That's why they always explained whether they were refering to the drive dog side, or the nut side. In my statements above, the front is the nut side, and the back is the drive dog side (most common way I saw in my searches).
                            Regardless of the terminology, the nut side is the one you wanna polish. The drive dog side is where you remove the material to do the balancing. You do not want to remove any material from the nut side.
                            For sharpening, you do most of it on the drive dog side, then hit the nut side with fine sandpaper to give it that razor edge.
                            • bwells
                              • Jan 2009
                              • 842
                              Okay, then I'm safe cause that's what I did except for filing a little on the nut side. I'll try that. Thanks
