Yes, porpoising... I may be adding some nose ballast since the hatch is soooo far back, I am limited in my batt placement. notice in beginning of vid how far forward the batts are? I am thinking a chunk of 3/4" plywood up in the nose..... or more strut angle.
38" H&M Intruder twin to begin
hey jesse 5s packs came in today funtime when jeff finishes my strut and wire driveTHUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVESComment
I gave her some more down strut, but she is still bobbing a little. after this run I gave it max down, have to see next run, hopefully tomorrow. She did really good though, came back reading 49 mph on GPS on 5S. She did a solid 40mph on 4S. does that mean 55 mph on 6S???
Another thing I haven't figured out is why she doesn't turn very sharp at high speeds... I have full turn available and have to let off the throttle to get her to turn.... Not sure if you can tell from this vid, but at slow speeds I have all kinds of turn, but at high speeds, I can't get her to turn sharper than maybe a 100' radius...???
"Look good doin' it"
See the fleetComment
Jesse is it possible that you are overpowering your servoNecessity is the mother of invention.............
Youtube Video's http://www.youtube.com/user/Titanis2000Comment
This is something I had not considered... I have a high torque digital servo (traxas) that I thought would have enough umph. But now that you mention it, that could be. What kind of force in a servo do I need for this? What do you recommend?"Look good doin' it"
A digital should have enough grunt , you might have to maybe see if you can stall it manually Jesse or see what kind of power it has just to eliminate it as a possible causeNecessity is the mother of invention.............
will try that this afternoon. hoping for another run tomorrow and if all holds together, may try 6S...
Are you setting the end points of the serve so the rudder is only turning about 20 deg. Each way?
EX President of the Offshore FE Vultures SocietyComment
I think the surface area is not a problem the thing is HUGE!!!
I just tested, turned it on and went left right, well it is actually a faulty servo ROD. I gave it too much angle and it BENDs with not much force. Need to redo the servo rod (it is .078" thick enough but too much bend. I need to head to Ace hardware first thing tomorrow.
Wolf, did you run today? or you just happy to see me?"Look good doin' it"
ran the elam... got a vid link under my build thread.. but im still happy to see youI think the surface area is not a problem the thing is HUGE!!!
FREEK'N' INSANE BROTHER!!!!!!!!!
